Final drive ratio
Old Mar 18, 2024 | 10:02 AM
  #91
Disarray's Avatar
Disarray
I wish 3.73's were an option on my F450. It does not need 4.30's for what I do and tow. For that matter, I didn't need an F450 either, but the price was really close to an F350, I could get it well under MSRP, and the wife was on board sooo why not.
I did hem and haw about going with a F350 DRW with the 7.3 and 4.30 gears. I just couldn't do it because ya know, "what if." I wish that I could go to a dealer and hook my trailer up to a truck during a test drive and see if it meets my needs. That would be great.
Old Mar 18, 2024 | 11:08 AM
  #92
WXboy's Avatar
WXboy
With 3.73 the trans can still gear down easily to adapt to any situation at lower speeds, but has the advantage of lower RPM on the interstates. With 4.30 you get zero advantage once you leave 1st gear, and you also lose the low RPMs at interstate speeds. To me it's a no brainer to go 3.73 unless you intend to tow near max capacity a lot of the time.
My last truck was a Ram. The options there were 3.21 or 3.92. I had the 3.21. It still towed the camper fine, it just did it one transmission gear lower than the 3.92 would have. But when not towing that low RPM cruising was niiicceee....
Old Mar 18, 2024 | 11:40 AM
  #93
00t444e's Avatar
00t444e
3.73s are fine for a 6.7, diesels have a much lower peak torque and operating RPM and a gas engine does so they don't need the axle gearing to be as low.
Old Mar 18, 2024 | 11:59 AM
  #94
GAZZILLA's Avatar
GAZZILLA
How about the 4,000lbs GCWR advantage and other towing advantages stated in Ford’s tow guide with 4.30’s? I guess that all just a bunch of nonsense?
Old Mar 18, 2024 | 12:09 PM
  #95
bigwin56f100's Avatar
bigwin56f100
Originally Posted by GAZZILLA
How about the 4,000lbs GCWR advantage and other towing advantages stated in Ford’s tow guide with 4.30’s? I guess that all just a bunch of nonsense.
That is the 1st gear advantage (4000 extra pounds on take off) otherwise, 3.55-3.73 have the advantage everywhere else.
Your TT probably doesn't even weigh 4000 lbs
Old Mar 18, 2024 | 12:14 PM
  #96
GAZZILLA's Avatar
GAZZILLA
That’s not what Ford’s tow guide states.
  #97
00t444e's Avatar
00t444e
4.30s have an advantage in every gear, not just 1st.
Old Mar 18, 2024 | 12:20 PM
  #98
GAZZILLA's Avatar
GAZZILLA
Most importantly to me, I like the way gas trucks drive with 4.30’s. Especially with bigger tires which bring rpms down.
Old Mar 18, 2024 | 01:44 PM
  #99
Strider250's Avatar
Strider250
Of course the 4.30's drive better with your bigger tires, the Tremor package with the 7.3 requires it. The 3.73 with your bigger tires would be a bit of a drag and I full agree with you. Most folks don't put on bigger tires and the 3.73 is fine for them.
Old Mar 18, 2024 | 02:23 PM
  #100
f250blueoval's Avatar
f250blueoval
Those are made up numbers in reality. SO he very well may not need them.
Old Mar 18, 2024 | 02:29 PM
  #101
twobelugas's Avatar
twobelugas
It is abundantly clear at this juncture that the small group of most vocal 4.30 owners don't understand how multi-gear transmissions work.
Old Mar 18, 2024 | 02:40 PM
  #102
00t444e's Avatar
00t444e
4.30s does much better even on stock tires for me.
Old Mar 18, 2024 | 03:02 PM
  #103
bigwin56f100
it depends on what you consider an advantage. I consider 75 mph for 1200 miles dead heading empty with 3.55 gears an advantage over 4.30.
4.30 gears you CANNOT cruise like 3.55 and that's the advantage if you need that advantage. I need that when empty mpg matters on a long trip. No reason at all to want to be spinning higher rpm's when it just isn't needed. That is a huge advantage when I'm cruising empty at highway speeds with the trailer in tow. 10th gear nice and easy. Return trip 10,000 lbs 9th gear. Its all good on my end.
Old Mar 18, 2024 | 04:34 PM
  #104
00t444e's Avatar
00t444e
4.30 gears with 33" tires in 10th gear is about 2100 RPM, great cruising RPM for a gas engine, still well below the torque peak. The 3.73s or 3.55s would put it even further away from it so no advantage there.
Old Mar 18, 2024 | 04:39 PM
  #105
OBS460's Avatar
OBS460
This isn't a genset peak torque also means peak fuel consumption. You are making plenty of torque at 1700rpm to maintain 70mph. Why would I want to turn 2100rpm when I dont even need as much torque as the engine is producing at 1800rpm? No vehicle produced is designed to be at peak torque cruising at 70mph.
