You are not gonna believe this, but these auto transmissions they put in the SDs these days, they automatically downshift when ECM and TCM decide it's time for some torque multiplication.
If you really want to go plebian, you can also downshift it yourself. But that's very advanced technique that only the pro drivers know how to do.
Yes I prefer to shift it myself, you get more torque and it's easier on the driveline to move the load with a lower rear gear in the same transmission gear as it is with a higher rear gear. What is the advantage of a gas engine to get 3.73s instead of 4.30s? None that I have found, plenty of disadvantages though.
Lower rpm when the engine doesn't need to turn 15% more RPM to get the job done?
I ask again, what load are you towing that 3.73 with the 10 speed would have a hard time to get moving? Reality check: if a load and/or incline is heavy/steep enough to damage drive line on a 3.73, your precious 4.30 is not gonna come out of it unscathed, well, maybe 15% less damaged but you still have to replace the damaged parts. LOL.
I guess this thread is about gas drive ratios. I just want to say that I am going to own a first ford superduty ever of my life. In fact first ford ever. I plan to tow a 12,000 lb travel trailer. The truck is going to be a 2024 f350 with 3.55 gears behind the 6.7 diesel HO. I have full confidence in this. I can't imagine that gas engines will be far too different. If I had the option, I would have considered gas. The limited only comes with diesel.
4.30 will move any load easier than 3.73s and gives you more available torque. You can argue all you want but it all boils down to basic physics. No advantages to having 3.73 gears over 4.30s on a gas engine with the 10 speed.
That is patently false. It allows the engine to turn over less when the condition does not require the motor to turn over as much as the 4.30 requires it to at the top end. If there is no appreciable difference, Ford would be putting in 4.30 in all their SD trucks, gas or diesels. And those millions of GM Gas 2500 and 3500s? They only offer 3.73 so in theory GM gas HD segment should be deader than a whistleblower in a hotel parking lot, with all their buyers flocking to Ford for the magnificent all powerful 4.30 gearing.
Since you continue to refuse to clarify what you actually use it for, I then have to assume your belief in 4.30 is a simplistic, one dimensional belief that ignores all the other advances Ford has implemented in their engine, transmission, driveline, etc areas. Ask yourself, did you buy a truck to do a job, or did you spec it because you have always spec'ed it a certain way in one very specific area and you just can't fathom technology has moved on from your assumptions? If more available torque at any given time is the one an only goal, we should all just man up and drive F450s with the PSD and 4.30 rear end, don't even bother with all this girly SRW wimpy gas nonsense or those old 7.3 PSD that are anemic at best.
Like I said before with 4.30 gears running 75 MPH you are already turning an RPM that is well below the torque peak of the 7.3, 3.73 gears would put you even further away from that so no advantages there. The only reason the offer 3.73s is to appease the group of people who are stuck in the 90s and automatically think that a higher rear gear ratio means you get better fuel mileage however that is simply not the case in the majority of situations with modern engines and drivetrains. Back when trucks came with 31" tires and only a .71 OD ratio it made more sense to get the 3.73s over 4.30s if you were going to be driving unloaded most of the time and only tow light. Now with them coming with 33-35" tires and a .63 OD ratio there is no reason to get 3.73s since 4.30 gears already has you at a low enough RPM as is.
But you do get better fuel economy with the 3.73s vs 4.30s with today's engine, transmission and programming. I know first hand.
At 70mph in 10th gear I'm turning between 2000 and 2100pm with 4.30s and 31.5" tires. That is high and unnecessary for long trips at high speed. Both gear ratios under the 7.3 got the best fuel economy around 1600-1700rpm once the converter locks up. There is zero need for peak torque at 75mph. You only need as much HP and TQ are required to move the load at 75mph.
LOL.
My 3.55 with 33 inch goodyear AT tires tows 10k just fine, 12k is no issue either, I get 18-19mpg at 65mph when not towing but still have about 500-1k in the bed.
If you find yourself relying on 4.30 behind a 7.3 gas and 10 speed just to tow up to 14-15k, perhaps it is time to re-learn how to drive.
What lugging? My 3.55 runs at 1600 RPM at 70mph. I have always had long legged gas Fords that run great at 1500-ish RPM, it's got enough torque north of 1k rpm that see it propelling the truck along leisurely doesn't bother me the slightest.
I'm talking around town, or roads 50mph or less, where an engine would run at 1000rpm in a gear.
I lock out gears until I'm at lest running 1200-1500.
If a 3.73 running 1000rpm at a certain speed, tire size and gear, a 4.30 will run 1150rpm.
If that 150RPM makes that kind of difference between lugging and not lugging, you need to get your truck in to a shop to check if there is a problem. LOL.
Good for you, I drove one with 3.55s and it was a complete slug, I definitely wouldn't want to tow with it. The 4.30 gears make a big difference over the 3.55s. Sounds like you drive like your old enough to be in a nursing home though so it probably works for you.
Not that I have noticed. Switched from 3.73s to 4.56 gears running 35s and didn't loose any MPG, actually gained close to 1 MPG running the back roads, highway mileage didn't change at all, and it pulls and accelerates much better than before.
You are insufferable. You realize that you are the mirror image of the posters you complain about....but it's OK because it's the 'side' you are on?
Why are you so triggered about this? You are cheerleading 3.73/3.55 much harder than anyone has ever praised 4.30's, but you can't see it because of your bias. Why do you promote less power to the wheels so intensely?
Originally Posted by twobelugas
or that the 4.30 imperative upheld as gospel by a small group of users
the elite gas 4.30 owners
you switched to 4.56s and 35s on an alumiduty with a 7.3 gas engine and a 10spd? If so you did not gain any mileage.
Hand calculated. 35" MT tires with 4.56 gears gets better mileage than the same 35s with 3.73s did. It did get better mileage with the stock street tires and 3.73s.
