New owner
That’s the typical recommendation around here. I’ve seen people say the deeper pan does not actually help to keep temps cooler as it just ends up being more heat soaked fluid. I run the 6.0 trans cooler and haven’t had any issues with temps.
What part of WV? My daughter is in school near Wheeling. We’re below Parkersburg close to I-77.
Between race bike parts, tools, and supercharger parts all piled in by the front door over the last two weeks my wife finally made me pile them in the garage.
Looks like you have quality up pipes so maybe not an issue. But with cheapo uppies look out for fitment of cast iron collector to baby's butt. I had to grind a fair amount off the Dorman collector to blend them properly.
Ended up cutting one bolt on the driver's side up pipes and breaking all three off the back of the turbo even after heating with map gas. Got all but one out and broke my extractor .
The kit I was sent for the bpv delete is definitely wrong. It has 5 bolts and my turbo only has 3 . At this point if anyone sells and upgraded hotside housing I'd rather just buy it and be done with it .
https://www.ebay.com/itm/AVP-Non-EBPV-Outlet-Ford-1994-97-7-3L-Garrett-TP38-Turbos/133264828530?_trkparms=ispr%3D1&hash=item1f0733e87 2:g:6MEAAOSwbm9d69rw&amdata=enc%3AAQAFAAACcBaobrjL l8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickkBUIiHw Yv5YgVss0WaiENz9Av9YwVWCSdhpgS2rLNF9SWoueLgqKLkZE0 %252FDJFE0%252FkZEqShxljc5Jrznb2u73Y4saZiK83NHJt6% 252B6DryxLvaou11nDrGfQL%252Bi1kXUbO0EkmuHI%252F
S ggfBm0oZYF7EJOqLc6hN059oAq9BB%252FLCbYIIyHXkQl44cb 0HU9KJrCT7hKT9jQefBOhKV453FlPBELfge4Kz6AUTDVEE%252 FfS79Bdi9hPIqtQLBBX7%252BOUg6ErDPGWiuQOoCYIM5aXnNw f0q92QgNDgFR7bVP2zdiQ4TaghdEiU5%252FQ3Uo8SGO0wgPmM LDmIcSoB5rrwLl7gLgwS6ZY0eEQf3RVPPDF1zvTP2DENfRpHHl SIMLvGm6N0Yx05cEKmO%252BKlxgszaG8F%252FzLLzquWNHdV 6gq2JkBbEzcp%252FNHZ9UixBbyNbpurK6Cif5fxvDqXfwPhKS AzSldW8p67AEcsMA9JA%252F0Umn6CKKqA%252BYiKVUtoItzF 0WpbLQvQaazhQEzzpQ7EL3sOu70LuaM%252B6dDshT85t5JALn HL7sXpd3o%252BRAs39hMPbECpYiYKD2glbLTBUIodXovSt150 %252FTGemnXcY7m5KmdHADwdUsj0o6Fw0djhUG6DdG6p1SI37s B5OaD2Fk354xH3wCB2h43VP6kqWfjopPKfCYGhnGMhpcWa4fYS NJSRWWozDJoltSpGFMwU4gnnLL44cf85e%252BaZR62FYCdlKQ h%252B7HdtQ0reSuS%252FJjuecXHO3SsXM5pFdZ39U7LvtH6r WBtvtjD9KjqT8A%253D%253D%7Ccksum%3A13326482853093e 1ae356848435cb2bb184458183e0e%7Campid%3APL_CLK%7Cc lp%3A2334524Alternative option is to modify the flapper outlet.
Pull the flapper out and gap the axle hole with freeze plug or weld it shut.
edit. I dont know why link went crazy?
Im going to order a 15mm freeze plug from amazon I guess but now this has me wondering.
I DIY delete EBPV’s. You can remove flapper and Rod, then use a freeze plug, bolt or weld the hole for Rod.
Still need an extractor to get the broken flush bolt out of the turbo housing.
Also not so sure the 6.0 cooler I ordered is going to work for the van its not set up the same so looks like I may have to come up with something different.
Seriously, if not too late I would add this to the order. You will already have the turbo apart. The riffraff 4x4 billet wheel will spool faster and prevent surge. It’s a great upgrade.
I bought a Riffraff 4/4 billet wheel and it was a great upgrade. I was really quite happy with it in the GTP38. The performance gains in a billet wheel is one of the best bangs for the buck.
I emailed them and asked them to cancel the housing and exchange for the billet wheel.
on edit: verify that outlet adapter is for a VAN if you are using it instead of just deleting yours. The trucks use a larger exhaust pipe and will not work. Most people buy that outlet adapter to use van turbo on trucks...
2nd edit: The van turbo has a 1.15ar ex housing, but also a larger turbine wheel. These parts are not interchangeable with truck turbo. The van turbo is ‘special’.
Have fun with it, that is what it is there for!
