bad vacuum line from the vacuum manifold on the firewall to the inside of the cab. look for a broken or cracked white 1/8 vacuum like going from the firewall to under the ac/heater box.
Seems like every truck I look at that line is either broken or missing. I've also seen my fair share of zip ties holding an actuator open..also done it a time or two myself..
you mean this line? Its all their and the actors do move unless its the one behind the radio.
its weird because it seems to skip over floor and go right to defrost or vent.. floor setting just blows out the defroster vent.
If you have or can borrow a vacuum pump you could route it to your HVAC system from under the hood and it's quiet enough you could probably hear where it's leaking.
If you have some know how an old fridge compressor makes a great vacuum pump.
the actuator at the bottom of the box does move and I noticed that it does not stop mid way where floor would be. It moves all the way forward or all the way back.
thats what I am thinking. I cant get that through work any more. Obsolete since 2010
When I got my 89 one of the studs for the vacuum connector on the HVAC switch was gone, and the cable wasn't the right length, ended up getting a junkyard unit and all was well.
the studs are their and the cable is too.. it does not look like it has ever been messed with
