'56 f100 build thread
The seat position relative to the steering wheel is about as comfortable as I can make it for my height and girth!
I had the bed sitting under a pop up tent outside the garage but we had a big storm come through on Friday so we set it on the chassis. It's sitting on 4x4 so I still have room to work on the fuel tank and wiring
Insulation is in on the floor and back wall. I left a trap door for the mc and am using a drop out battery box. I like the design of the older steering wheel and it was in better shape than the '56 one I have so I'm going with it. I have some crud in the steering shaft that I need to push out so I can run the horn wire.
Thanks for posting the pictures. Helps keep us motivated too!
Ken.
- fuel tank is fully installed and filler is mounted in bed
- wiring is 80% done
- brakes are fighting me and it really stinks having the master cylinder under the floor when trying to fix brake lines. New proportioning valve on the way since I stripped the threads on one of the outlets.
- front and back glass are in. My son helped and the back was easy. Front took about two hours of wrestling to get it 99% in. Of course, I broke it trying to get the last bit to set in. So another windshield will be going in next month.
I'm starting to do body assembly and hope to fire it up by the end of the weekend.
I wish You all a quite first advent Sunday!
i understand the concern. The c-notched frame isn't this chassis, this one has stock suspension and frame under it. I do think the other frame is plenty strong, though. You go from a 2" by 4" C shape frame to effectively a 2" x 2" square tube. My understanding is that you have the same surface area, just splitting the 4" vertical into two 2" inch verticals.
- Section modulus. This measurement, in cubic inches, is based strictly on frame side-rail height, width, and thickness. As a frame of reference, the section modulus for the standard frame on a Chevrolet Kodiak C7500 is 9.58 cubic inches, while the strongest frame option for that chassis offers a section modulus of 17.93 cubic inches.
- Yield strength. This factor refers to the maximum weight in pounds per square inch (psi) that can be placed on the frame allowing it to return to its original position without permanently bending or creasing. Typical yield strengths for Class 4-7 trucks range from 50,000-120,000 psi.
- Resistance bending moment (RBM). This calculation combines section modulus and yield strength and seems a fair and accurate measure when comparing frame strengths between truck manufacturers. The formula: Section Modulus x Yield Strength = RBM. Revisit the previous example with the standard frame strength of the C7500. Here’s how the numbers compute: 9.58 cubic inch (Section Modulus) x 50,000 psi (Yield Strength) = 479,000 RBM. In comparison, the strongest frame option on that truck offers 2,151,600 RBM, based on a section modulus of 17.93 cubic inches and 120,000 psi yield strength."
Am I understanding correctly from your post that the key is the thickness of the original frame vs the thickness of the boxing plate? And if the boxing plate is less thick then the 2x2 is less strong than the original c shape frame? Or are you staying that the 4" height of the c frame makes it stronger than any square tube that is less than 4" in height?
I appreciate the info.
Seats and carpet are in. I left the carpet lose for now until I finish the brakes. It will tuck under the firewall cover and I bought stainless brackets that will hold it down along the door frame. Do you guys typically glue the carpet in spots or just hold it down like that?
Rear fenders ready to go on.
Ug. So close to getting the windshield in. I got impatient and used a little body panel pry bar to try and slide it in. I wouldn't recommend that approach!
Here is a YouTube vid if it will post.
