'56 f100 build thread
Would someone measure their '56 cab across the rear lower door frames? See pic for what I mean.
I'm most interested in outside to outside by where my thumb is here. This would be relative to the door jamb on the driver's side. If my total cab width is off here then I know it is a problem with this jamb.
Door jamb is caved in at bottom 1/3
Rocker panel bends in the last several inches
Front passenger floorboard looks ok.
Firewall came out nice. No rust to speak of.
If the rest of the window frames look like this I will be in business!
Also test fit my bench seat. It's out of a 1991 f150. If I put it close to the floor I'll be able to drive pretty comfortably. It's tough at 6'4" to fit in these things.
Seat from drivers side
Hope this is what you needed. I just skimmed thru your posts and really enjoyed what you have done so far. Thanks for sharing the pictures. This is from my '53.
Ken.
Rear c-notch. Instructions say to leave more than half of frame height
You raise a great point.
The c-notch is exactly half of the frame. I know it looks like more but it's because of the angle of the photo. The frame was 4" at that point when I started and now it is about 2 1/8". I'm hoping that with the full boxing it makes it strong enough but I'm also curious to see how it handles the weight. I'm less concerned since it's a pickup and there is less weight on the rear end than if it were a car. It's something I'll keep a close eye on, though. I would be curious to hear from members who have done the c-notch before.
I wish You all a quite first advent Sunday!
Definitely a lot to consider. Towing and heavy loads aren't in the plan, nor is autocross. You guys are right, though, the 302 I'm putting in will have about 300 horse at the crank and then lose some through the aod so it's probly double or triple the original power.
I'll give no limit engineering (the makers of the kit) a call next week and talk this through with them.
The frame was originally 4" span with 2" to make the C shape top and bottom. Now it is essentially 2" by 2" square tube. I'm not sure the difference in strength there.
As I've said before, the truck was hit hard on the passenger side at some point. The mounting holes for the support took some Carnage. One I had to replace with a new plate and recreate the oblong hole. The other I was able to weld up. There were a few stress cracks near the one I welded up so I grounded a u into them and filled them in as well.
This is the drivers side one that I had to cut out.
Passenger side that was able to be hammered smooth and welded up the damage.
Repair plate welded in on drivers side
Welds ground down
1/2" wide oblong hole. I drilled two 1/2" holes then filed down the material in between them
Driver's side finished
Passenger side finished
Fixed xmember and installed steering rack.
Here is the dash when I started. The worst part is above the glove box where a stereo was mounted, then removed and replaced with tin and Bondo.
Bondo gone and tin pushed back. This is the area that I would like to get a patch panel for. I think it would be very difficult to get the radius and Apex right.
