The engine that failed
Old Jun 7, 2019 | 11:53 PM
  #181
pmuller's Avatar
pmuller
First check to see if the carb throttle is full open when the gas pedal is depressed to the floor.
Then Please put the Q-jet back on.
The 465 cfm Holley with vacuum secondaries will not produce a good 300 six engine response.
Also adjust the timing so the total timing with all the mechanical advance in is at least 34 to 36 degrees with the vacuum advance disconnected.
The initial timing needs to be more than 12 degrees.
Old Jun 8, 2019 | 08:17 AM
  #182
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Is the 465 made for circle track like the 390?
Old Jun 8, 2019 | 09:40 AM
  #183
AbandonedBronco's Avatar
AbandonedBronco
You could always do the old trick of delaying the secondaries a bit. This is something that automakers actually did back in the day. Even though you should never really feel the secondaries come in (ideally, it should be a very smooth transition) the delay in their opening would produce a surge in power that people really liked, so they did it on purpose to make the car "feel" more powerful even though it was slightly less.
pmuller, out of curiosity, why wouldn't the Holley 465 work on his engine? Too small? Some particular design characteristic about this carb?
Old Jun 8, 2019 | 01:16 PM
  #184
F-250 restorer's Avatar
F-250 restorer
The 465 Holley was initially put on small v8's in the late 1950's. I'll be running the Quadrajet and the Summit 600, although not simultaneously, ha ha. I wanted to run an 800 cfm QJ, but I checked and I only have a 750. The diff. is only on the primary side; the 800 having a slightly larger diameter throat (venturi). For some reason GM put the 800 on several small v6's like a 231 ci. I checked and I have the air bleed restrictions needed to properly (I hope) calibrate it to my engine. Hopefully, having a carb with under 200 cfm on the primary side will help with the low end sluggishness I'm experiencing.
Regarding the Summit 600: This carb, and the tech behind it and its annular boosters, was created by Ford as an Autolite 4100. Holley bought the rights from Ford and produced the Holley 4010. It bombed b/c it didn't look like a Holley. Twenty years pass. Holley adds Holley floats, jets, secondary diapham, float level adjustment and windows, adjustable air bleeds, and is now making them for Summit, using the same annular fuel discharge. I did some research and found that the 500 cfm and the 600 cfm have the same venturi. The only difference is that the 500 has a smaller i.d. booster, which allows less air flow. That means that the 500 cfm is NOT going to produce better throttle response on smaller engines. Ford made a 4100 with smaller venturi (the 4100's stamped 1.08, a 485 cfm model) for engines with less displacement. But Summit/Holley has tried to capture a larger market by taking the 600 cfm and dialing it down while spending the least money possible.
Pmuller: I have 16* mechanical advance. The shop that did my distributor had it on a Sun machine and said to run 16* initial, giving 32* total.
Old Jun 8, 2019 | 09:15 PM
  #185
pmuller's Avatar
pmuller
It appears that a vacuum operated secondary opens later than what the 300 six requires and yes a 465 is on the small side for a modified 300 six.
I started a thread so we can collect a broad spectrum of carbs being used along with engine response.
https://fordsix.com/viewtopic.php?f=2&t=80035
F-250 restorer
I will be interested in the results of your carburetor swaps.
Thanks for taking the time to post your findings.
Old Jun 10, 2019 | 01:08 PM
  #186
AbandonedBronco
The secondaries wouldn't affect driving at the lower RPMs he's having issues with though, would they? That seems to be in the 1000 - 2000 RPM range, which should be all on the primaries.
Even then, the secondary opening rate can be affected by springs, as well as an aftermarket plate to allow for other jets (as opposed to the metering plate). I had those on my 465.
Old Jun 10, 2019 | 04:46 PM
  #187
AbandonedBronco
Another question for you, K.
What is your engine vacuum at idle, once it's all warmed up?
Old Aug 18, 2019 | 01:55 PM
  #188
F-250 restorer
I wanted to re-check the mechanical advance. I thought I would use the oe timing index or pointer, with the t. mark on tdc, and transpose the 16* mark onto the balancer, and simply measure and add two more of the 16* measurements around the circumference. Is there a better way?
Also, using an allen wrench inside the v.advance canister through the hose attachment changes the amount of v.advance. Which way is which?
Old Aug 19, 2019 | 09:21 AM
  #189
78Fords's Avatar
78Fords
If i remember correctly turning the allen screw inside the vac advance does not adjust the amount of timing but the speed that you get it. when you turn it, it will adjust the amount of tension on the spring that keeps the diaphragm closed.
I should have read back into your thread but... did you replace the dist? if you didnt there is a good chance the mechanical adv is stuck or not operating correctly. if you did replace it then all you should have to do is find your base timing.
Old Aug 19, 2019 | 09:51 AM
  #190
AbandonedBronco
When I added timing marks to my balancer, I lined up the timing mark with the 10° mark on my timing cover. Then made a mark on the balancer on the 0° line. Rotated the balancer until the mark was at the 10° again. Made a mark at the 0° line, etc.
Continued until I had timing marks up to 60°.
To check mechanical, put a timing light on it and then slowly rev the engine. If you do it with the screw on the carb and raise the RPMs incrementally, you can write them down and record your timing curve.
Then, get a handheld vacuum pump, put a hose on the vacuum advance canister, and slowly add vacuum. For each 1hg of vacuum, record how much the timing jumps.
This'll also help with adjusting the canister for the advance timing to come in earlier or later.
Old Aug 21, 2019 | 09:44 AM
  #191
F-250 restorer
Thanks, AB. That's a good method. I believe I have several msd timing mark tapes. If I have one for my balancer size, maybe I can tape that on to get the marks. Since the balancer is on now, I'll use the easier system.
Old Aug 21, 2019 | 10:11 AM
  #192
AbandonedBronco
Let me know about the timing tape, if you would. I've always liked the idea of it, but our balancers have such a narrow edge on them that I've never found a tape that fit.
Old Aug 21, 2019 | 10:28 AM
  #193
F-250 restorer
Sorry, I should have been more specific. I meant using the tape as a means of revealing where to mark the balancer. You are correct. Our balancers are too narrow to apply the tape.
Old Aug 21, 2019 | 01:34 PM
  #194
pmuller's Avatar
pmuller
I had just enough room to use the MSD 8985 timing tape at the edge of the balancer after trimming off the numbers and just using the tick marks.
You can still see the longer 10 degree lines and you can put dots at the important locations.
Old Aug 21, 2019 | 08:48 PM
  #195
F-250 restorer
Funny, I got a new timing light today--one that is compatible with a multi-spark ignition. I had pretty much timed it by vacuum and ear, and hit the mark almost right on! I had it at 16* btdc, and the engine loves it. It smoothes out and runs fine, long, steady pulls in each gear. I didn't ck the advance due to an injury, but will get to it.
