Side mirrior recomendations..
Old Jun 1, 2018 | 08:42 PM
  #76
bigb56's Avatar
bigb56
I noticed on the 1-A auto mirrors if you order the ones with the interchangeable caps they come with the adapter to the round plug, but the plain black ones don't. Same price too.
Old Jun 2, 2018 | 07:23 AM
  #77
Silverhks's Avatar
Silverhks
Thanks for that Y2KW57, I didn't even check if the round connector had enough available pin slots. I think you have the winning setup.
Old Jun 2, 2018 | 10:34 AM
  #78
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by Stewart_H
I thought all side mirrors on these bad boys came with heated mirrors?
Stewart
If by "these bad boys" you are referring to Super Duty trucks, then no, they definitely did not all come with heated mirrors. In fact, for the first three production years 1998 (E99), 1999 (99.5), and 2000, heat was not available in the mirrors at all, not even in the full boat Lariat models. My 2000 Lariat with power trailer tow mirrors did not have heat... nor did the mirrors swing both ways. Back in 2001, it was an extremely popular mod to swap out 99-00 model year mirrors for 2001-up mirrors, just to get them to swing both ways and to add heat. Then people would swap again in 2003 when the signal mirrors came out. Then again when the larger convex mirror came out in 2008. There was an FTE member here who switched his mirrors out four times, and he only had 25,000 miles on his rarely used truck. His name was Neil, and I've wondered what has happened to him. He's in NorCal too.
Anyway, the point is, anyone with 99-00 Superduty who has the heated mirror markings on the glass of their mirrors (like mine now do) no doubt is not running the original mirrors that Ford shipped with the truck. They have been replaced/upgraded. This was so common, that an aftermarket industry developed to meet the demand.
On the other hand, if by "these bad boys" you are referring to aftermarket mirror replacements.... then I have no idea which aftermarket mirrors have heat and which do not.
Old Jun 2, 2018 | 12:41 PM
  #79
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Couldn't help myself, I felt compelled to post the video below...
Old Jun 2, 2018 | 12:42 PM
  #80
Stewart_H's Avatar
Stewart_H
Yes, this bad boy...bad boy number one.
Thanks for the info.
Stewart
Old Jun 2, 2018 | 06:59 PM
  #81
bigb56's Avatar
bigb56
Anyone know the turn signal wire colors on a 2002 truck?
Old Jun 4, 2018 | 10:24 AM
  #82
brian42's Avatar
brian42
Veteran: Navy
Turn signal wiring diagram for your 2002.
File Type: pdf
Old Jun 5, 2018 | 07:54 AM
  #83
bigb56's Avatar
bigb56
Thanks!
Old Jun 6, 2018 | 08:02 AM
  #84
L-ight's Avatar
L-ight
On the truck side, yes. Since you're truck does not have heat, turn, and marker lights from the factory there are no wires that run to the doors for those functions.
Some have run wire and spliced them into the mirror harness wires. Others have gotten the connector pins, crimped the new wires onto them, and inserted them into the mirror plug (truck side) for an OEM appearance. It also makes it easy to remove the mirror if you have an issue or want to replace them. I bought these connectors (Ford Wedgelock Pin Type Terminals 20-18 Gauge .060" Pin Diameter) but haven't installed them so don't know if they are the right ones. These are the ones that a couple of other users listed (F250RockStar and ligito) so I went for it.
I also have a timer relay to connect to the heat when I do the job too. The 6.0L trucks had heat but it was tied directly to a "hot in run" circuit so that any time the truck was on the mirror heat was too. I read complaints of spots on the mirrors so I didn't want the heat always on. Some have gotten a defroster switch from a '95 Explorer that has a built in timer. It is a similar appearance to what is already on the dash but is different enough that it doesn't pass my OCD test so I will use a regular switch with a relay wired in...just my preference.
I was going to wire them up during my injector debacle but getting the job done to my OCD level was too time consuming and is something I need to do as a primary project. Most everybody else would just have at it but I had a lot of stuff torn apart and would have been guessing at the final outcome (wire lengths, routing, slack, etc.) that I know I would have been disappointed with the results.
So odds are my 03 F250 has the round connectors and not the flat ones? Also what relay do I need to grab as I will just run the heater to the relay for both mirrors? I will most likely just use some quick splice connectors and not cut anything.
Old Jun 6, 2018 | 11:23 AM
  #85
brian42's Avatar
brian42
Veteran: Navy
My truck has the rectangle connectors.
I picked up a time delay relay from Wolsten Tech Innovations but you can get them from lots of places. I plan to hook it up to a momentary switch so I can turn the circuit on (with timer) and turn the circuit off with another push of the switch.
There are probably less expensive options out there but the guy was willing to talk with me on the phone, understand what I wanted so I'd get what I need, and then explain it all to me. The timer is adjustable and it looks like a quality product. It's also been sitting in my garage for 3 years now still waiting to be installed.
Old Jun 6, 2018 | 11:28 AM
  #86
L-ight's Avatar
L-ight
I was just wondering if I could pick up a timer relay from Autzone or something? I also really think my truck may have heat. I notice when there is dew on it in the mornings it starts to evaporate off the center towards the outer edge. Could be wrong though.
Old Jun 6, 2018 | 11:34 AM
  #87
brian42's Avatar
brian42
Veteran: Navy
You might. Relays are avaliable all over, especially if you are looking for a fixed time.
I've read of quite a few that have gotten a 1995 Explorer defrost switch. It has a timer built into the switch and is a (somewhat) match to the interior. That could be an option too.
Old Jun 6, 2018 | 12:58 PM
  #88
L-ight's Avatar
L-ight
So basically just go and find a relay for the window defroster and wire it up into acc on/ground?
Old Jun 6, 2018 | 01:39 PM
  #89
brian42's Avatar
brian42
Veteran: Navy
As long as the switch has the timer built into it...yes. Some were set up for the switch to trigger the programming (time delay) in one of the vehicle's computer modules.
Old Jun 6, 2018 | 01:54 PM
  #90
axmrdr's Avatar
axmrdr
Like Brian said, if it doesn't have a timer it would be easy to forget to turn it off.
If mine isn't wired for a defroster I don't think that I will go to the trouble of hooking it up, and I am a master electrician lol.
