The plastic housing on mine fits just a little bit loose at the top as well but to be honest so did the original mirrors. You can see there's a little Gap at the top in the pictures but I have rain guards that tuck in behind them and the fit is almost exactly like the mirrors that came on the truck. I'm not worried about sealing up because there's so much insulation and Rubber seal on the new mirrors that with the bolts pulled down tight it's fully sealed.
The new mirrors did their job last week, definitely made backing the boat trailer easier. Here are some of the guys lined up just after we crossed the border into Mexico, waiting for the rest still going through behind us. Mine is the white rig with the Thule and boat. We were a formidable bunch and no one dared to mess with us
Has anyone connected the tun signal on the ebay ones? One of the reviewers said it was very fainy, barely visible. I am wondering if he only looked at it from inside the truck. I was hoping when I get around to connecting them it will make lane changing easier when towing
Got the eBay mirrors and they look very nice. Much bigger than my stock mirrors.
I plan to wire in the turn signals and parking lights per the link provided above. Also bought a set of power door lock actuators that I will install at the same time.
I've never returned anything from ebay....I suppose you just pay return shipping?
Just thought i would add that i emailed the company that i bought the mirrors from on ebay and explained they did not fit correctly. They sent me a brand new pair for FREE, without having to return the old ones. Being that they were $120 , i thought that was pretty impressive...
I ordered a pair this morning. I've hit my mirrors on trees, garage doorways etc... they're brittle and showing their age. Replaced the aging headlights last year and it made a huge difference on the looks of the truck These should make the truck look brand new ;-)
I installed the driver's side mirror yesterday. The mirrors did not require alteration before mounting as I had thought they might based on other posts. Took a little bit to get them lined up properly but once I did it slid into place.
The adapter they provide hooked up just fine and I tested the mirror controls and everything worked as it should. This took about 20 minutes including removing the door panel. The next 2 hours were spent wiring the turn signals and parking lights.
The mirrors do not come with any instructions or wiring schematics. In fact, I couldn't even find a manufacturer's name on them. I'm still not sure how to access the side marker and turn signal bulbs for replacement.
Wiring the mirrors was more difficult than I had thought it would be. The wire colors on the new mirror were different, the colors on the adapter from the new mirror to the OEM plug were different and the colors designated on my F250 wiring manual were different from what was actually on the truck.
Fishing the wires through the flexible tube from the door to the cab was real trying. I found unplugging the tube from the cab side and collapsing it as best I could made this much easier, however there are plenty of obstacles to maneuver around inside the cab as well.
I ended up removing the gauge cluster to gain better access to the wiring.
When soldering the wires for the driver's side, I went ahead and did the passenger's side also and fed them under the dash to the glove box area. Later today I hope to tackle the passenger's side install.
Finished the installation today.
New mirrors with power adjust, parking and turn signal lights.
New power lock actuators.
To top it all off, I remembered I had brand new Kicker front speakers still in the box I had bought for my previous truck and never installed.
I like these mirrors (ebay brand from link provided by Sous) as they are much bigger and provide more visibility than the stock ones. Can't wait to see the difference when hauling the 5th wheel with these mirrors rather than the cheapo rubber band extenders I have been using.
afmedic did it. I think he said it was the same as replacing them on the OEM style and there was some sort of release or catch that you could move from the mirror side.
The wire coding is as follows: New Mirror wiring: White - attaches to black, on OEM plug on 2000 model Yellow - attaches to Dk Blue (left side) Brown (right side) on OEM plug on 2000 model Orange - attaches to Red (left side) Green (right side) on OEM Plug on 2000 model Blue - powers the parking light (lower light on mirror) Red - powers turn signal light Gray - powers heat Black - Ground
