I didn't know the value of the resistor/fuse..so, grabbed a piece of 14ga about 1" long, wet the ends and soldered it in... You guys might get lucky and your resistors are there. You'd just need to light hit them with a solder pen👍
^^^ that was exactly my thought..hope its a 610 resistor, because the 680 are tucked under the screen, lol
. Managed to finish the gauges. Now, its just an unplug ur and out comes the dash..also, egt probes
Pass side Drivers From dash Houston, we have contact
Minus firing ur up for hoop sealant curing reason, think,..she's done..
•axle swap, overhead console fix, w.p.replacement, CCV mod, gpr led mod, gauges, hpop rebuild, turbo rebuild, weld up pedestal, grill insert, coolant, h/h and trans filter bypass, led everywhere, f650 dash, braided fuel lines, 6.0 cooler, trans flush...only thing left I level kit😊
FP sender w/loom everywhere Covered every tube in lube Connection for overhead gauges Double n f650 dash/gauges
For the GPR LED mod, did you put a terminal on the GPR or tap into the line somewhere? The only reason I ask is because I am unable to see a "new" wire or connection on the GPR.
Everything else looks great! I hope it fires up the first time for you and it all works.
