Best budget turbo or turbo rebuild
My turbo blew in my 2000 ford excursion.
I already have have it and the pedestal out.
The car has 315k miles on it so looking to get it back on the road economically.
Any suggestions on for good quality but econical parts I should put into it?
parts I may need:
parts I may need:
- turbo or rebuild kit (I haven’t opened the turbo up yet to see what happened but there was lots of grinding I heard and there is lots of oil in every tube going to or from the turbo)
- orings for turbo and pedestal
- new bolts for turbo and pedestal?
- New turbo hoses?
- intercooler? Not sure how much oil got in there
- Pedestal without ebp? https://www.dieseltruckpartsdirect.c...iABEgKUdvD_BwE
I have a modded turbo that has a relatively recent rebuild and a non-EBPV pedestal...for sale.
You probably can't pm yet so contact me at vossmachine@gmail.com if you might be interested.
Clay at Riff Raff diesel will have what you need. I would do the pedestal delete if you don’t need it. Look at billet wheel as an upgrade. Check Plenums, maybe do the inserts, new clamps, check the up pipes replace with bellowed ups. HPOP hoses if you have the originals still in the truck. Passenger side fuel line. Only use OEM orings.
parts I may need:
parts I may need:
- New turbo hoses?
1. I used the Garrett GTP38 journal beariing rebuild kit but the 360 kit is the popular item now.
2. Always install new o-rings (2 sets) when re-installing the turbo. It's not worth saving the pocket change to have to pull everything back apart because of a $1 o-ring. Riffraff sells a re-install kit that comes with new o-rings and bolts.
3. It's been awhile since I had my turbo out but I treat those bolts as TTY. I don't re-use them. New bolts come in the kit I mentioned in #2.
4. What do you mean "hoses"? If you are talking about the boots I wouldn't replace them unless you have a problem with them or they are damaged. I would get better clamps first. Clean the boots with brake cleaner and put on some good clamps and you should be okay unless you're sled pulling.
5. I wouldn't worry about oil in your IC...it's already there. Your CCV dumps into your turbo inlet so oil has been running through your intake since the first time it was started.
6. I have that as well as the "high flow" non-ebpv outlet. I'm happy with it as I no longer have potential leaks from that system, but I do live in a warmer climate than most.
I would recommend that you inspect your up-pipes. If you have the funds I recommend putting some bellowed up-pipes in there. I went the IH route but many have been happy with the Dormans for a fraction of what I paid for mine.
I have the 360 kit (includes O rings, new bolts and housing seals), a 5x5 billet wheel, EBPV delete housing, the resistor for the pedestal sensor plug and the 33 psi W/G actuator waiting for when I pull mine out. I think I came out right around $300. I'd suggest cleaning as much gunk out of the valley area as you can. From what I've read it seems that the pedestal can be a culprit for leaks.
Shawn MacAnanny
02-08-2017 05:36 PM
Burke4344
15
10-30-2010 08:14 AM
powerstroke96ryan
05-11-2008 02:55 PM
