Famous pedestal leak - Ford Truck Enthusiasts Forums
Old 01-20-2018, 03:44 PM
krobbins krobbins is offline
krobbins is starting off with a positive reputation.
While i plan to do the delete, should i rebuild my turbo? If so, what kit do i get and how much is it and level of difficulty.
Old 01-20-2018, 05:10 PM
DISLFVR's Avatar
DISLFVR DISLFVR is offline
Locomotive breath
DISLFVR has a very good reputation on FTE.DISLFVR has a very good reputation on FTE.DISLFVR has a very good reputation on FTE.
Contact Guzzle at Diesel-o-rings, he has everything you need. The rebuild kit is easy to do.
Old 01-20-2018, 06:26 PM
beef tits beef tits is offline
beef tits is starting off with a positive reputation.
I threw in a GTP38R when I did my pedestal. Nice turbo; similar to stock except it will flow a lot more air, reduce EGTs, and make way more power on less boost if you go with bigger injectors.
Old 01-20-2018, 08:11 PM
Quote:
You talking a LOT of $$$ for that set-up.
Old 01-20-2018, 08:13 PM
Quote:
Indeed, but the time to do it is when you already have it apart...
Old 01-22-2018, 11:50 AM
brian42's Avatar
brian42 brian42 is offline
brian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to behold
I used the Garrett rebuild kit from dieselorings.com and put in a billet 4/4 wheel from riffraffdiesel.com. My rebuild kit has the OEM 270 degree bearing where others are offering 360 degree kits now. I also bought all new bolts for the turbo housing since they had been subjected to 280K miles of heat cycles. The rebuild is more time than cost to complete. You will need a 1/4" drive 12pt 8mm deep socket or you won't get to some of the bolts. Mine still looked good on the inside but it was a small price to pay to get the maintenance/refresh done while I already had the turbo out. I would much rather line up the baby's butt once.
Old 01-22-2018, 11:54 AM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
Hey Brian, that flake never came thru Saturday with parts. Hope you had a cool weekend with the FAM...them bolts your referring to, I just did mine and think, they're 5/16 12pt socket needed
Old 01-22-2018, 12:26 PM
DieselOrings's Avatar
DieselOrings DieselOrings is online now
SPONSOR
DieselOrings has a great reputation on FTE.DieselOrings has a great reputation on FTE.DieselOrings has a great reputation on FTE.DieselOrings has a great reputation on FTE.DieselOrings has a great reputation on FTE.
Speaking with the Garrett technicians, Garrett has no plans to develop a 360 deg thrust bearing kit. To have a thrust collar that covers the full 360 deg surface, the thrust bushing has to be made into 2 pieces rather than the 1 piece bushing that Garrett uses. They feel this leads to a much weaker thrust bearing overall and adds nothing to the thrust bearing's functionality.
Bob -- aka guzzle
__________________
Specializing in Viton o-rings and leak repair kits for the 7.3L diesels
(970) 368-4455
guzzle's Mods & Maintenance website
Old 01-22-2018, 04:11 PM
brian42's Avatar
Quote:
Bob -- aka guzzle
Thanks for the info. Reps sent!
Quote:
No problem. With the government shut down the marine base skills center was closed all weekend so I wouldn't have had time anyway. Instead I spent it at home working on the house. Maybe next time.
Old 01-23-2018, 11:27 AM
Sous's Avatar
Sous Sous is offline
Sous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant future
Brian has some great information for you. I rebuilt my turbo with a full kit from SPTurboost when I installed the deleted pedestal. I also installed the RiffRaff 4/4 wheel.
I am glad I did these because following the instructions on RiffRaff and SPTurboost made the job very easy.
I put some good pictures and information in the thread below.
https://www.ford-trucks.com/forums/1...-planning.html
Worth rebuilding the turbo and installing a billet wheel, yup...
Old 01-23-2018, 12:11 PM
Wesley Green's Avatar
Wesley Green Wesley Green is offline
Wesley Green is starting off with a positive reputation.
Subscribing. I'm waiting on the high flow outlet to get back in stock, then I can join the cool t-shirt crowd too. Already have the SP 360 rebuild, RR 4/4 billet wheel and pedestal.
How long will it take someone to do an EGR delete kit? 02GrayPowerStroke 6.0L Power Stroke Diesel 33 07-06-2017 07:57 AM
My hat lefty1953 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 03-17-2017 10:06 AM
Pulling someone out of snow question Bt-99 Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 8 12-20-2016 03:44 AM
What does the ambient air temperature sensor do? El Campo Cooling, Heating, Ventilation & A/C 1 06-26-2016 01:31 PM
Down Pipe removal? Restlesswildman Excursion - King of SUVs 9 05-09-2016 11:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
