*** The Official Superduty Morning Coffee Thread ***
The following 2 users liked this post by ESwift:
The following users liked this post:
Finally sold food at my first event. The weather was great, the festival crowded, and I sold out in about 4 hours with lots of "best ever" declarations from customers. Put about $700 in my pocket too.
Today I feel like I got ran over by a truck in a forest fire. Gotts do something about all the smoke leaking around the doors of my smoker.
The following 7 users liked this post by rjdj1186:
@ESwift do you have a FORScan file showing ICP not keeping up in a hauling situation that could be used as a baseline for this upgrade? You are using a modified single HPOP now, right? And it's not keeping up?
Looks great! I use this on my Green Mountain Smoker, I also put a cam style lock on the door to pull it closed rather than just gravity. It made a huge difference!
The adrenaline keeps up on normal tunes towing 13k+
My cts2 shows me all the live data needed.
As stated I wanna see how far I can push things.
Duals will only improve thingsThe adrenaline will stay on bottom then a ffd re-release of bts dual setup will go above. That runs a reverse rotation hpop on top
I was gonna do a Terminator setup, but he doesnt respond to contact. AA touched base with them for me and was told he is not making any more duals for now. I think terminator is having parts supply issues like most places. Quite frankly, of he isnt willing to return any inquiry on a $3k part, I am glad to go somewhere else and not hve my time wasted.
Looks great! I use this on my Green Mountain Smoker, I also put a cam style look on the door to pull it closed rather than just gravity. It made a huge difference!
https://www.amazon.com/dp/B091JXCCS6...ing=UTF8&psc=1
That is exactly what I used, but it didn't do the trick. It made it hard to close the doors and centered the smoke leak at the middle, but I have some gaps in there behind the overlap on the doors where the frames of the doors are a good inch apart. Gonna need a welder, I think.
I put these to hold the door tight against the seal I listed above…they made a noticeable difference in the seal. I also used this caulking to “build up” the seal where the door didn’t close perfectly. I don’t think you can truly get an airtight seal with an average smoker.
That said, I haven’t seen this CNC Fab STG2 pump go over 30% DC and it easily holds +2800psi with these 238/100’s.
I am a fan of the stock fuel filter, but I guess I could get over that. I’ve built a few custom fuel systems I’m proud of....
