Installing new A/C compressor, etc.
Old Aug 10, 2017 | 10:39 AM
  #106
bcamill's Avatar
bcamill
Have you done a pressure test on the cooling system. You could have a small head gasket leak. You may see that the coolant is down some after driving for a couple of days. You may not notice bad performance as not enough coolant entering the cylinders to change it much. Also no coolant in oil as it is a limited leak and is being burned off in the cylinder. I have seen this with the same problem in the past.
Jonness
1997 - 2003 F150
Jul 1, 2016 07:46 PM
InfantryCPT
May 8, 2015 02:42 PM
kc7smo
May 22, 2006 09:16 PM
1/2ton
Aug 8, 2004 11:28 PM
Jquest
Sep 26, 2003 06:53 AM
