Took the old girl out for a drive on Saturday! All the way down to Atlanta Hartsfield International Airport. Thinking of becoming an Uber Driver.....-Just kidding.
Happy post here. No problems at all. Drove incredibly the entire trip down and back. It's about 65-70 miles round trip!
Just wanted to thank y'all for the help. JeffFAFA especially.
You're welcome but Thank You for letting us know the Great news. Happy to hear it. And Happy to hear closure to a problem.
Well Gentlemen, it's been WAY over a year with no trouble out of Black Thunder. I had it parked for a while late this summer and now I can't keep the battery full. After installing a brand new battery, it was dead in 2 days. I looked under the hood to see if there were any obvious issues and didn't see anywhere where wires were damaged, although I did see some little varmint ate my washer fluid hose. I just pulled the Negative cable off the battery and checked with a Test Light and there is no indication of a complete circuit. I did the same thing with the Positive Cable/Terminal and nothing there either. So I'm wondering how I can check to find where I have a short. What order do I go in, where do I start etc. Any and all help is appreciated as always.
"Dead in two days" is a pretty healthy draw, seems like it should light up a test light.
Try the ammeter setting on your VOM? Modern cars and trucks have an acceptable parasitic load of 50 milliamps or 0.05 amperes, but old school iron should basically be 0.00 ... because they don't have all the clocks and gee-gaws & heated massage seats and wi-fi and the rest of it.
Charge the battery up thoroughly with an external charger. This will take a long time if it's dead. Don't try to do this with the vehicle alternator.
Now, it may just be alternator not be charging? Once battery is re-charged, re-install it. Run up the idle to around 2000 or so with the headlights on and heater fan on HI, radio playing etc, the idea is to really load up the alternator to get a true test. Measure voltage right at the battery posts. Should be north of 13.8 volts, somewhere around 14.5 maybe. More if it's super cold temperatures.
After it's charged, leave it disconnected from the truck for two days (if you don't need to drive it that is) and see if the battery is dead again.
Or if you have to drive it, just disconnect the battery at night to see if it lives.
A battery can fail internally and go deal all on it's own without any outside influences. Just a bad battery, and though it usually happens to older batteries, it can happen when new or old.
Especially when that battery has been drained a time or three before, and then perhaps sits for awhile. Sounds like yours falls into that potential category.
If the battery stays fully charged after sitting disconnected, the battery is OK and there is a drain somewhere in spite of you not seeing it initially with that test.
In this case, for out vintage of vehicle it's "usually" the alternator and/or regulator. The alternator has diode arrays inside that can fail and since it's hard wired directly to the battery the diodes let a certain amount of power go to ground. Kind of a "partial short-circuit" I suppose you could call it.
You will usually be able to feel the alternator body as quite warm, or the charge wire warm as well.
Even though both regulator and alternator were replaced, there's no comparison between today's parts and the ones we could get twenty years ago. You can still get good ones that last a lifetime practically, but it's way more common to get parts that wear out or fail in a much shorter time. Anywhere from 1 day to three years maybe, but when things used to last for decades while the body turned to dust (rust) it's a factor in our hunt for gremlins.
But at least you can do the test with disconnecting the cable to see what happens.
If it's not a dead cell in the battery, I'm guessing that it will come down to the regulator, or the alternator. Do you have the 3G alternator set-up? If not, and the alt. turns out to be the problem, do the 3G swap. IF all three of those items are good, then check out the ignition switch. Let us know what you find.
Sometimes it's stuff we don't notice like the door jam light switch broken so they get pushed inside the body housing out of the way.
Over the yrs the wire can come in contact with metal and cause a short that drains the battery.
Also same goes for the glove box light.
Check that the Dome light is not staying on.
Anything is posable!
Orich
I did this today and it bounced between 13.8 & 14.5 or so.....it was around 45-50 degrees here today. The truck hadn't been started since last week, so it was dead cold.
Good luck!
Paul
After doing the other test, I disconnected the Battery cables and will let it sit until Saturday to see what's up.
You mentioned in your reply to Tedster that it had not been started in a week or so. Was the battery on the charger for all this time, or did it sit while not connected to the vehicle? Or was it connected?
Just curious how it sat for a week almost and did not drain.
Those are reasonable numbers but it shouldn't bounce. Fluctuating? That is, when RPM is held steady at 1500 or 2000, whatever you choose, the voltage should hold steady or near enough.
Paul
It has always been connected to the truck. the last time we drove it to get our Christmas tree, I had to jump start it. At that point it had been sitting for a while...(like a month or so...) so I didn't think it was a big deal to need to jump it; the battery is almost 2 years old and doesn't get a lot of use on it. THEN the next time I tried to drive it, it was dead again (no lights, nothing, not even the dome light) that's when I bought the new battery. Drove it once, parked it and then 2 days later, completely dead again. Just a very faint click when I hit the key. That's where I find myself today. Had the battery on the bench charging all day, checked the battery with meter (without the charger...) and read a little over 12, like 12.13 or something as I recall. Installed and she started right up. Read the meter with E'r thang running full blast and that was the fluctuation between 13.89-14.5. It's in the truck now but disconnected. Hope that helps.
That's good news then. They need to add a "Like Button" on here.....LOL! We shall see what happens on Saturday.
Hey Gary,
I'm just now going back through and reading everyone's posts from the other day. I replaced the Alternator last year but I don't remember whether it's the 3G or not. To be honest I vaguely remember reading about that, but don't know anything else about it. I also did the Regulator as well at that time. (That was back when I was trying to figure out why it would just lay down in the middle of anywhere...LOL) It turned out the Regulator was bad and the guy I bought it from did not have it wired correctly. There is no plug on my F.A.S.T wiring so I had to figure that our when I did the alternator. It's ok now though; I think. :-)
