No flooding here, first it has to get a lot warmer than what I`m seeing in the latest forecast.
You`re having problems with the upper or lower denture?
Kind of glad its an easy day here, only building a base for the big tool box and starting the heating duct, had enough hard work moving snow the last couple of days .
I needed to clear an area for electrical access and cleared a work area plus got rid of the 28' long snow bank along the fence line so that my yard wouldn't flood out.
Tossed it over the back fence so that it could melt into the alley there's a storm drain at my lot line. The rest went to where it could melt under the tree.
Is that a full or partial upper denture Perry?
You have to pace yourself John, I have problems with as my back too. A blizzard Friday is headed this way Friday, sounds like it`ll bring snow and high winds.
Full upper denture Morris, if the dentist doesn't thin it out and make it smaller, I will.
We had to much snow for a confined area and my yard would be flooding out next week as theres a double digit couple of days coming up. Tomorrow is a cool day so I'll cut up my propane tank some more and check out some options for my ducting, I need to get some T's or figure something out.
My full upper denture is big and bulky till I got used to it but it`s manageable now Perry. I don`t like that it diminishes some of the taste of food.
I have quite a big area to pile snow so it`s not a problem except if I`m not careful in a few tight ares. I forget what you are using that propane tank for.
I can't even drink water with this thing, and it causes me to choke when I'm not eating or drinking anything, it's virtually impossible to talk with it in. either I cut my tongue in half or this thing gets reshaped as its impossible to use except to wear it for 5 minutes at a time. I'm making a stove from the propane tank, it's the most work for a single item and is the last piece to go into the shop.
