1966 - 1977 Early Broncos
Tim's Bronco Build
Old Oct 27, 2024 | 10:30 PM
  #376
SlikWillie's Avatar
SlikWillie
Looks like a busy day. Good job!
Old Oct 27, 2024 | 10:33 PM
  #377
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
Thanks Willie, It was a long day for sure.
Old Oct 27, 2024 | 10:34 PM
  #378
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Almost a shame to put a body on top of that beautiful frame and all that hard work, but it sure looks good together.
Old Oct 28, 2024 | 04:27 AM
  #379
Desert Don's Avatar
Desert Don
Looking good Tim. It seems as though you are making progress in a forward direction!
Old Oct 28, 2024 | 06:04 AM
  #380
SavageNFS's Avatar
SavageNFS
Great job Tim! It looks fantastic!
Old Oct 28, 2024 | 07:02 AM
  #381
Jigger2020's Avatar
Jigger2020
Right on Tim, well done so far !!
if a shim under the trans mount isn't enough clearance, maybe modify the valve cover ....
Old Oct 28, 2024 | 09:39 AM
  #382
77&79F250's Avatar
77&79F250
Have you 100% the hood to intake clearance ? Now might be the time to think about a 1-in body lift?
That might take care of both little problems.
Before I'd modify the valve cover, I'd modify the firewall.
Old Oct 28, 2024 | 11:32 AM
  #383
McLeod's Avatar
McLeod
What engine do you have? 5.0 ?
I have the 351W and the drivers side head (not the valve cover) clears the firewall by less than 1/4 inch. I was anticipating issues but so far it has not been.
Also had issues with headers. I have long tubes and the driver side rubbed the frame rail but when hot I went down with a pry bar and levered it a bit but only gained a small amount of clearance. After logging about 500 miles I went down to look and it now has more than 1/2" clearance probably due to pressure being applied when tubes were hot while driving.
351w to firewall clearance:
your engine looks to sit lower and further back then mine
Old Oct 28, 2024 | 12:00 PM
  #384
Tim Young's Avatar
Tim Young
351W based 427 stroker Hence the 4-link, not so much for off road as it is keep things from twisting up.
Old Oct 28, 2024 | 07:57 PM
  #385
Chad149's Avatar
Chad149
Nice progress Tim! Gonna have to come out to silver lake for me and Toyman to show ya around.
Old Oct 28, 2024 | 08:29 PM
  #386
Tim Young's Avatar
Tim Young
Thanks Chad, That would be fun to come play in your dunes!
Old Nov 21, 2024 | 11:05 PM
  #387
77&79F250's Avatar
77&79F250
Did you get the couple of minor issues straightened out? What is happening now? Stay motivated, like eating a elephant, one bite at a time.
Old Nov 23, 2024 | 06:36 PM
  #388
Tim Young's Avatar
Tim Young
Not much, I have the inner finder cut away from the header on the passenger side. I have the inner finder cut but not put back together yet for the shock clearance on the drivers side. I think I'm going to modify the valve cover for clearance, just haven't got to it yet. Been looking at the Hydroboost I have I think I'm going to modify the mounting of it as well. I have a list of things I need to order, not much for Black Friday savings but maybe a little.
Old Nov 23, 2024 | 07:05 PM
  #389
Jigger2020's Avatar
Jigger2020
Solid plan Tim, I know you'll make it awesome.
Old Nov 23, 2024 | 07:10 PM
  #390
77&79F250's Avatar
77&79F250
Steady wins the race, and it is looking awesome.
FYI Black Friday deals.
James Duff https://dufftuff.com/blackfriday/
Wild Horses also. https://www.wildhorses4x4.com/ford-b...parts-specials
Toms Off Road https://tomsoffroad.com/ford/bronco-...THexM6VPSUDIns
