726-40-01
factory setting for F250 (60&65 PSI)
0104 3C41 01D8
The middle numbers are the values. 60PSI= 3C, 65PSI= 41
enter these values to get correct PSI
50PSI=32
55PSI=37
60PSI=3C
65 PSI=41
So 50PSI Front and 55PSI rear would be 0104 3237 01D8
Again, I am no expert. (Insert disclaimer)
I can confirm that this works for the 350 as well. Thanks again. It's worrisome when the system resets and you don't have any pressure showing, but when you start driving around, they come back.
Thank you good sir. My poor Chocolate puppy was a bit upset when I was in the bank for 5 minutes with the alarm going off. Had to take her for a Krispy Kreme to get her right.
