FOREScan software installed
Old Sep 29, 2016 | 07:26 PM
Rutcutter's Avatar
Rutcutter
I got the BT module this afternoon and got everything activated on my laptop and headed out to the truck. I'm having a few small issues and im sure it's me learning a new system and all but any help would be appreciated.
I was able to activate the fog lights with the high beams..
Very impressed with the light output.
I was not able to activate the trans and oil temp to show on the cluster..
Every time I went to write the value it would go to 50% and stop and not sure why..
I also was unable to find the tpms sensors to adjust the tire pressure threshold and the disable the double horn honk feature.
I was unable to find the heated steering wheel full hot feature and the mirrior spotlight functions yet.
I see ALOT of adjustments to be able to made when some other folks that's smarter than me figure out the thresholds like the adaptive steering and I even seen what I believe is the Torque management system in there also..
Old Sep 29, 2016 | 07:30 PM
EpicCowlick's Avatar
EpicCowlick
Ooooohhhh, Torque Management! Maybe allow full torque in 3rd gear?
Old Sep 29, 2016 | 07:49 PM
wb6anp's Avatar
wb6anp
maybe ask on the fordscan forums, Also according to the owners manual, the trans temp is already available, for the upper rt gauge
Old Sep 29, 2016 | 08:19 PM
System's Avatar
System
Prolocutor
I had a feeling you'd have some fun....
Old Sep 29, 2016 | 08:36 PM
Rutcutter's Avatar
Rutcutter
Yea but very intimidating at 1st... There are a lot of things that can be changed that's for sure.
I just took a drive and the fog lights on with the Hi beams is major bright!
Old Sep 29, 2016 | 08:42 PM
Rutcutter's Avatar
Rutcutter
Pure brightness!
Old Sep 29, 2016 | 09:41 PM
Bat4x4's Avatar
Bat4x4
Where did you get the thing to do the fog lights and how much was it? Do you think that it will work on the spot lights on the side mirrors also?
Old Sep 30, 2016 | 08:57 AM
Katymike's Avatar
Katymike
Trailering
Thats cool stuff! I downloaded FORScan and ordered the Bluetooth adapter yesterday. Do y'all know if it will it allow for speedometer adjustments for larger tires?
Old Sep 30, 2016 | 09:37 AM
Rasty1's Avatar
Rasty1
Love the lights! My I suggest you become our guru and teach how to program our trucks.
Old Sep 30, 2016 | 09:50 AM
Owenage's Avatar
Owenage
I am curious if Ford will care that this software was used? Will this effect warranty at all?
Old Sep 30, 2016 | 11:39 AM
System's Avatar
System
Prolocutor
It will not affect the warranty. You're not tuning. Your just changing settings that Ford programmed in from the get go.
As to tire changes, you can change size but only to another size that was available on your truck's configuration. No custom sizes.
Old Sep 30, 2016 | 06:47 PM
SwensonBarrettBunch's Avatar
SwensonBarrettBunch
Has anyone been able to turn the DPF % gauge on
Old Sep 30, 2016 | 06:55 PM
Rutcutter's Avatar
Rutcutter
Not yet just now got the Double horn honk deleted and the Tpms psi threshold lowered down to 55 psi in the rear.
Old Sep 30, 2016 | 07:04 PM
Marching Ant's Avatar
Marching Ant
...As to tire changes, you can change size but only to another size that was available on your truck's configuration. No custom sizes.
Can you enter custom fuel tank sizes? If so, are you limited to only two digits?
Old Sep 30, 2016 | 07:09 PM
wb6anp's Avatar
wb6anp
youll have to put in this thread, how to make the changes. Id like to do the fog lamps, when I get my truck and maybe the tpms. you lowering the pressure for the ride when empty? They also have a thread for the codes to mod tings like the double honk titled Master List of Ford As-Built data modifications.
