Transmission temperature sensor
Old Aug 7, 2016 | 05:02 PM
  #76
Yahiko's Avatar
Yahiko
Originally Posted by FICMrepair.com
I didn't know if you wanted that publicized, Sean.
Yup, Sean called me and explained what all was going on. In case other's reading this don't know, Sean is top shelf people. He just cares about his fellow man. I'd be happy to have a beer with him anytime.
Hang in there, Marine! You're in good hands with these guys.
I don't mind. Sometimes I found that talking about a problem or a design that you have can help you see what your missing. The guy that got me
really hooked on electronics used to do that when explaining things to me. I can think of one time when he had me helping with a project and he was
explaining the system that he said "I see a problem" We were working on a Head CT Machine interface that had to be hand built for some new image
display equipment we were adding to it. One of my tasks was to build all the interconnecting harnesses.
The point being that sometimes that can be your best tool for troubleshooting they don't even have to know the system. The process of explaining the problem
makes you think about what you have done and also makes you come up with a new way to describe it to someone that in turn can give you new insight to a problem.
The hardest job is doing remote diagnostics by text or voice. I like to be there and put my hands on but by doing it remote I have to work even harder to make things clear
so that the person on the other end can understand my thinking. Yes I go off on tangents.
So if you ever think I am nuts when I describe something or come up with a set of tasks. Just let me know and I can check my work and maybe come up with a better
way to do something.
Benny Ed is right your doing a good job.
Sean <BR>
6.0L Tech Folder
Old Aug 7, 2016 | 06:28 PM
  #77
usmarine1979's Avatar
usmarine1979
I was one of those threads a while back, and without the help of this amazing community, I'd still be there. Since buying this truck, with the help of this forum, I've been able to:
Replace hpop and oil cooler
Clean the turbo
Install new injector o-rings
Install new stand pipes and dummy plugs
Replace the ball joints
Replace the tie rods
Replace rear bearings
Replace front hubs
Install new rotors, calipers and pads
Replace the tft sensor (twice)
And now diagnose the transmission issue
I've never really worked on cars with electronics before, all of my wrenching experience has been on late 60s Mopar, and classic cars. And even through building 5 classic cars I never once worked on a transmission. Somehow I have am innate fear of messing it up.
I am truly thankful for everyone who contributes here.
Old Aug 7, 2016 | 07:30 PM
  #78
BLADE35's Avatar
BLADE35
thanks Guys
I agree doing it face to face with someone is way better
Old Aug 7, 2016 | 08:43 PM
  #79
Yahiko's Avatar
Yahiko
Clean the turbo
Replace front hubs
One very nice thing about the old points and coil it did not take much voltage to make a spark.
They also are less likely to have issues if there is an EMP right when someone drops a- Abomb.
Here is the thing about transmission shops. They want us to think that there still black magic
involved with working on an automatic transmission. That keeps the money rolling in to the shop.
Sean <BR>
6.0L Tech Folder
Old Aug 8, 2016 | 09:06 PM
  #80
usmarine1979
Well crap. Add a new water pump to the above list. It's Donatella been a Monday.
Old Aug 8, 2016 | 09:22 PM
  #81
BLADE35's Avatar
BLADE35
shoot Iv had a Terrible day too
get a metal impellar pump
Old Aug 8, 2016 | 09:46 PM
  #82
usmarine1979
Got one ordered, now to abuse my poor 1/2 ton with what my 250 would do with ease.
Old Aug 8, 2016 | 10:39 PM
  #83
usmarine1979
Here's to hoping both of our Tuesdays are great
Old Aug 14, 2016 | 03:23 PM
  #84
usmarine1979
Interesting turn off events, the water pump went out before the new harness came in, so I changed it. I haven't put the new harness in, and the transmission hasn't had an episode yet. Could it somehow be related to the water pump failing?
Old Aug 14, 2016 | 04:21 PM
  #85
BLADE35's Avatar
BLADE35
it could have been just the plug getting a better connection at the trans messimgwith it to test
Old Aug 14, 2016 | 07:47 PM
  #86
87crewdually's Avatar
87crewdually
Actually there is an issue that can occur if the fan clutch harness has a damaged wire. I'll try to find the article. For now I'd inspect the wires very carefully near the plug of the fan clutch.
EDIT:
Alright I was thinking of a different scenario but still this article is worth a read.
Shorted Fan Clutch article
Old Aug 14, 2016 | 08:23 PM
  #87
usmarine1979
EDIT:
I just touched that harness, never even crossed my mind to check it regardless of its relevance to the transmission. I think I'll be double checking every wire I touch from now on.
Old Aug 15, 2016 | 01:31 AM
  #88
Yahiko's Avatar
Yahiko
Also look at the harness where it splits the fan and coolant temp sender for any soft
insulation. Ant diesel that has gotten on insulation can cause it to soften. If you find
that then look for any un-insulated wires.
Sean <BR>
6.0L Tech Folder
Moataboat
Feb 24, 2019 07:36 PM
TNT in Round Rock
Jan 24, 2012 03:58 PM
bearhugger
Sep 18, 2009 10:32 AM
2002f2507.3LPS
Nov 8, 2006 03:26 PM
trinogt
May 24, 2002 07:55 AM
