SCT Livewire TS EGT solution
Old Aug 14, 2016 | 08:45 PM
BjornF16's Avatar
BjornF16
Is there a current (and reliable) EGT solution for SCT LWTS+ ?
Or should I go standalone Autometer or ISSPRO?
Old Aug 15, 2016 | 03:03 AM
Boomer89's Avatar
Boomer89
I run the SCT 9817 EGT Kit for my Livewire TS+. Bought mine on Amazon from Rudy's Diesel for $145. Fairly simple install with instructions. I drilled and tapped into the drivers side manifold right near the bend towards the rear, install probe and tighten, ran the cable/wire through the rubber grommet under the go pedal (it was the shortest and easiest route into the cab for me), plugs right into the main cable coming from the OBDII port, setup Analog #7 I believe for your reading and off you go!
Iaff113
Jan 29, 2017 09:04 AM
HowieE
Dec 4, 2016 11:35 AM
Macmathews
23
Aug 18, 2016 03:14 PM
Trav460
Dec 16, 2007 12:14 AM
IDPisan
Jan 15, 2007 03:05 PM
