Transmission temperature sensor
Old Aug 7, 2016 | 12:53 PM
  #61
BLADE35's Avatar
BLADE35
Sweet you got this
Key was in On Position when testing right??
Old Aug 7, 2016 | 12:56 PM
  #62
usmarine1979's Avatar
usmarine1979
Originally Posted by BLADE35
Sweet you got this
Sigh..............
Old Aug 7, 2016 | 12:57 PM
  #63
usmarine1979
Sweet you got this
Quick correction, that is at 5.03v
Old Aug 7, 2016 | 01:01 PM
  #64
BLADE35's Avatar
BLADE35
PCM/External wire harness is GOOD
So internal wire harness or sensor
Go to step B4
set DVM to Ohm and test things going into trans DVM set to Ohm Pin 18 & 22
Old Aug 7, 2016 | 01:02 PM
  #65
usmarine1979
I am also now getting the audible tone when testing resistance from pin 18 to pin 22.
I swear I'm not typically this dumb, I am just overwhelmed at this point. I promise you the next time I'm in Utah, I'm buying you a drink or 14. Your patience and help is such a huge difference maker for me right now.
Old Aug 7, 2016 | 01:22 PM
  #66
usmarine1979
Ok I'm having a hell of a time trying to get my leads on the pins on the side of the transmission. Can I get to it better internally?
Old Aug 7, 2016 | 01:25 PM
  #67
BLADE35's Avatar
BLADE35
[QUOTE=usmarine1979;16479647]I am also now getting the audible tone when testing resistance from pin 18 to pin 22.
QUOTE]
what side of the plug at trans were you on at this time
or
leading back to PCM
anytime a DVM is set ohm or continuity you do not want to Feed it power or the DVM may not be calibrated correct or work at all
Testing at the Trans plug going back to PCM side with Key ON would have feed DVM power 5.03 volts to be exact
If so touch the battery terminals to verify DVM Accuracy reading a 12 volts range and nothing crazy DVM set to read DC volts IM sure tons of other things come into play when testing a DVM for accuracy Probably yours is OK
OHM pins 18 & 22 going into trans side of things
There are so many rules to electronics testing that its hard
Old Aug 7, 2016 | 01:30 PM
  #68
usmarine1979
[QUOTE=BLADE35;16479694]
QUOTE]
or
leading back to PCM
leading back to the pcm
Testing at the Trans plug going back to PCM side with Key ON would have feed it power 5.03 volts to be exact
I've got a 5" exhaust pipe directly in front of the Trans side plug making it impossible to see where my leads are, much less if they are on the right pins. I might have to go get some alligator clips or something
Old Aug 7, 2016 | 01:33 PM
  #69
usmarine1979
Tested the DVM on the battery, all is good there
Old Aug 7, 2016 | 01:35 PM
  #70
BLADE35's Avatar
BLADE35
well you most likely need an internal harness at this point
I find it hard to believe you got 2 bad TFT Sensors
At the TFT sensor 2 pins comong Directly out the sensor set DVM to OHM or Beep and if it beep its OK to a Point Use ohm value per the temp on step B4 scale to verify sensor integrity
Old Aug 7, 2016 | 01:37 PM
  #71
usmarine1979
Thank you sir. I will be tracking one of those down then.
Old Aug 7, 2016 | 03:48 PM
  #72
usmarine1979
Oreilly has one I can special order, I think I'm going to call ford tomorrow and price theirs.
On the plus side, while I bake in these triple digits, it's nice to see my transmission chillin
Old Aug 7, 2016 | 03:55 PM
  #73
Tideman's Avatar
Tideman
Quote:
Originally Posted by BLADE35 View Post
Sweet you got this
Sigh..............
USMarine1979 you have kept yor sense of humor thru this whole thing. You sir are a good man.
Old Aug 7, 2016 | 04:02 PM
  #74
usmarine1979
Thanks Tideman, it was a struggle at times. I drove to oreilly's in it and thought the issue was gone. For the first time I saw what looked to be legitimate Temps until it started bouncing erratically again, then dropped to that pic and lower. At this point, my sense of humor is all I have left.
Old Aug 7, 2016 | 04:09 PM
  #75
diesel_dan's Avatar
diesel_dan
Hey, your truck is running! Read a few no-start threads and you'll feel a whole lot better about just a flaky trans temp.
I'd have to go back through your thread to see if this was asked, but what does the dash gauge do while this is going on? Edit: Ignore this last idiot sentence
