Project : EXCURSION
Old Jun 16, 2016 | 06:22 PM
  #121
Yahiko's Avatar
Yahiko
I see what the problem is you linked a HTTPS:// and not HTTP://
That is what I get when running an old browser on an oil system.
InjectorsDirect.com ? 6.0 2003-2007 MOTORCRAFT OEM REMANUFACTURED FUEL INJECTORS
This one works once you remove the secure connection requirement.
Sean <BR>
6.0L Tech Folder
Old Jun 16, 2016 | 08:44 PM
  #122
FordBlueHeart's Avatar
FordBlueHeart
Originally Posted by Yahiko
The link is dead.
Sean <BR>
6.0L Tech Folder
Works for me. Almost ordered a camouflage hat for 18 bucks...lol
Old Jun 16, 2016 | 11:33 PM
  #123
87crewdually's Avatar
87crewdually
You must have a picky browser Sean. Works on android chrome mobile.
Old Jun 17, 2016 | 01:47 AM
  #124
Yahiko's Avatar
Yahiko
Older version of Safari. Not updating certificates.
Just one more reason Tim Cook should be boiled in oil.
Sean <BR>
6.0L Tech Folder
Old Jun 17, 2016 | 08:39 PM
  #125
Per4mance's Avatar
Per4mance
Got the passenger side complete today. The cups where a mess. Took a lot longer than I expected to clean them to my standards. All torqued up to 24 ft pounds (old style injectors). It is very clean inside the motor considering the oil was so black when I changed it. I will finish the drivers side in the A.M. and service the lower fuel filter and put the updated drain on there too. Hopefully we will have a running truck tomorrow that doesn't smoke like a train.
Old Jun 18, 2016 | 09:26 AM
  #126
Per4mance's Avatar
Per4mance
My side kick is waiting for a ride. She said I'm takin too long with this project. If it's not one female it's another
Old Jun 18, 2016 | 05:22 PM
  #127
Per4mance's Avatar
Per4mance
Well it's up and running with no smoke, I have some issues thou. The alt is a piece of garbage. That definitely has to be changed. The FICM has to go to Ed. I should of sent it 2 weeks ago but that's another tale. Defiantly getting the Atlas 40. If you look at the Snap On scanner,you'll see why I say it has issues.It could be a bad inject from Ford. It's got a new FICM harness so that's not it. Maybe I'll take Jack up on his IDs offer before I send the FICM out
Old Jun 18, 2016 | 08:41 PM
  #128
BLADE35's Avatar
BLADE35
195 an inject is the best OEM deal Iv seen so far
OHM EACH COIL (+ AND -) IF GOOD SHOULD SEE 4 OHMS OR LESS
AND SHOULD BE OPEN TO EACH OTHER and open to the Body of the Inject
Old Jun 18, 2016 | 09:09 PM
  #129
Per4mance's Avatar
Per4mance
I haven't figured out if it means cylinder #5 or #5 in the firing order
Old Jun 18, 2016 | 09:14 PM
  #130
BLADE35's Avatar
BLADE35
P0273 Cylinder 5 Injector Circuit Low
Fault Detection
• The FICM circuit fault detection is unique from other Ford circuits. The FICM measures current to determine if
an injector coil is open or shorted.
• Open coils produce low current which sets the injector circuit low codes (ie. P0261, P0264, ... , P0282).
Im curious what you find
Old Jun 18, 2016 | 09:33 PM
  #131
Per4mance's Avatar
Per4mance
So it is cylinder #5 which is the second from the back on the drivers side....correct?
Old Jun 18, 2016 | 09:37 PM
  #132
BLADE35's Avatar
BLADE35
second from back passenger side
Old Jun 18, 2016 | 09:44 PM
  #133
Per4mance's Avatar
Per4mance
OK, I'm thinking GM, my bad. I'll ck it tomorrow. Pull the FICM too and the pins
Old Jun 18, 2016 | 09:48 PM
  #134
Yahiko's Avatar
Yahiko
Got something for you. UI forget this all the time so I have this to lean on.
Hope this helps you as much as it does me.
Sean <BR>
6.0L Tech Folder
Old Jun 18, 2016 | 10:08 PM
  #135
87crewdually
This may help too.
