Full resto finally
Old Oct 14, 2016 | 04:56 PM
  #91
88beast's Avatar
88beast
Ya I agree plus more flatbed space with the added width. I will feel a lot safer with the duals and don't know how far I will push it so I'm leaning that way.
Old Oct 14, 2016 | 08:41 PM
  #92
Diesel_Brad's Avatar
Diesel_Brad
Holy crap!!
You are NUTS for even considering to "fix" that cab
FYI, the rivets for the vin tag are nothing special
BTW I live in PA too and there is no such law stating you cant weld within any proximity of the vin tag
Old Oct 14, 2016 | 08:44 PM
  #93
88beast's Avatar
88beast
Well fixing is more sentimental than anything. I've had the truck 10 years since I was 15. It has taught me a lot about automotive repair and it's lucky. Plus vin rivers are star shaped and that's a lot of work to make a river that shape. Most of the hard stuff on the cab is done. Now it's hust full in the holes.
Old Oct 14, 2016 | 09:21 PM
  #94
'89F2urd's Avatar
'89F2urd
I've been down the road of saving rusty bodies, I don't regret what I've done but I won't be taking on any rusty restos any time soon. The good thing about these trucks are the availability of replacement panels of all sorts.
To each his own. "His own" can evolve as well, he's learning a lot about the process..may not feel the same way the next go round when it comes to this kind of work, but he'll be familiar with how to do it.
Old Oct 14, 2016 | 09:22 PM
  #95
88beast's Avatar
88beast
Ya this will be the last rusty truck that I fix.
Old Oct 19, 2016 | 09:56 PM
  #96
88beast's Avatar
88beast
New and old you can see how bad it was
Inside
Straightened the fender liner support piece
Back in place to see what lines up and how bad the rust was
Cab support in place for mock up
Well got the cab mount out tonight. Here's pics
Old Oct 20, 2016 | 05:03 AM
  #97
Diesel_Brad
I dont know what rivets you are looking at, But they are not special.
And if they were like GMS "special" rivets. 30 seconds with a dremel would put the little groves in them. You have to remember where the vin tag is. In the dash, behind the windshield in a pocket. NOT out in the open for all to see
Old Oct 21, 2016 | 07:46 AM
  #98
88beast's Avatar
88beast
The top part is original and was just straightened out. The bottom was bent welded and shaped to replace the bad portion.
All cleaned up
Other side
Some mock up test fit pictures
Last night I got the floor support section repaired. Had to fab up over half of it. But it's thicker than stock and will be plenty strong.
Old Nov 3, 2016 | 09:34 PM
  #99
88beast's Avatar
88beast
Well been busy but not on the truck. The psd needs to get ready for winter. Picked up an 06 exploder for the woman and have been dealing with a lot of bs on my car with sands ford worst dealer ever.
Anyway I wanna get the engine out of the frame tomorrow and get that covered for winter. If I'm lucky I'll put the trans in place and fab up mounts. That way it will be easy to get the cab back on. Or maybe I should do the t case mount first. Still need to hook the 7 speed to it. I'm thinking a drive flange with a splined end to go into the tcase any opinions here?
Old Nov 4, 2016 | 04:50 PM
  #100
88beast's Avatar
88beast
Connector will supply 12v battery powr whenever needed. It's rated at 350 amps so it will be enough for a large winch or jumper cables
Side view I love these things so much better than popping the hood
My hand for a size comparison
Well didn't pull the engine but got a battery source connector on the psd for the plow winch. I will be putting one of these on the black truck once it's done too. It will be send for a set of jumper cables and other things.
Old Nov 10, 2016 | 03:58 PM
  #101
88beast's Avatar
88beast
Got a good bit done today it now needs to go on it's back so I can work underneath A pillar patch
Cab support in
In again
Floor pan cut in place
Started welding it in. The fit was horrible. But I'll make it work. I'd like more support to the a pillar than just a weld so some angle will be added.
Old Nov 11, 2016 | 06:59 AM
  #102
Diesel_Brad
I gotta say, I give you an A for effort
Old Nov 11, 2016 | 08:22 AM
  #103
MeTo's Avatar
MeTo
^^^ x10 ^^^
Old Nov 11, 2016 | 04:01 PM
  #104
88beast's Avatar
88beast
Got the engine out of the frame today. No pics was in a rush before dark. I also got a lead on a cheap dt360 I may pick up before winter. Let's hope it pans out because then I can do an in frame kit on it and have a pretty fresh engine.
Old Nov 13, 2016 | 05:05 PM
  #105
'89F2urd's Avatar
'89F2urd
I give him an A for effort, and an A for a backyard resto with who knows what welder.
Not everything needs your patronizing approval/disapproval. Surely I could have had a field day with your spelling a thousand times by now.
