Full resto finally
is your name supposed to be '89FTurd? No joke, I can't figure out if that's the joke behind your username, haha.
So some updates it's either been 100% humidity or raining lately so I just got the wiring connectors in place. Also got the plow mounted on the psd but will need to get lights still.
Also got the front skid plate cleaned and painted.
Plow mount for the psd. It's really sturdy so we'll see how it works.
I have 2 of these going through the firewall. With all the lighting and add ins the painless 28 circuit harness needed some wires added to it. So now I'll need to make the other hole for the second connector once the cab is pulled. Weather pack is the only good thing gm ever did.
Location on the firewall where connectors will be. The hole on the right is where the other one will be mounted.
Connectors to make the doors come off without re wiring.
Finally the cab is removed. I didn't know these were so front heavy. Either way it's done.
It's gone
Tcase
Engine
Also painted the fender dark red. I like it
All covered up till the engine and trans are pulled.
On the dolly but she needs to go higher
More of the cab in garage. Small garage so I don't got much room
Removed wiper motor and found some original paint. The rest of the fire wall is original also under the grease
Cowl wipers etc out
Dents from a 3 inch dp install. If you ever have the engine out or the cab off do this with the access not with everything together.
Rocker rust and dirt
Why the rockers get so bad on these trucks.
I found good metal
Pulled the outer rocker off and here's the remains of the inner
New inner rocker sitting in place
Bent up patch panel
After final trimming
Backside welded in
Another shot with the flash
Outside of a pillar hole.
Patch panel cut
Welded in both patches. This has the rocker fully attached to the a pillar.
Inside shot.
More of the inside of the a pillar.
All welded up and welds cleaned up. You can see how the rocker will attach to the a pillar in many places.
B pillar where the rocker attaches. I'll be measuring everything tomorrow before installing the rocker permanently. However I used the other side for reference so we should be good to go
Top of windshield
This looks drilled out here
