Newbie to here....
During one of the showers, I decided to tackle to the clutch slave and pushrod install. I decided to stick with the stock ’58 master and slave and fabricate whatever I need to make it for the ’76 FE motor and '76 T98 trans/clutch. I need to go with hydraulic because the steering box is right where the ’76 mechanical linkage mounts. Before today, I had not addressed the clutch at all and was really concerned I would have to pull the transmission to cut and alter the clutch fork. Glad to report I actually had the fabrication figured out and completed in a little over an hour and didn't have to alter the fork..
First I pulled the header to make more room. I forgot about the stock threaded holes in the block where the mechanical linkage was bolted. Made things easy. Once I held the slave in there, I could see that all I had to do was cut a piece of 1/4" plate to mount to the stock holes and hang down so the slave could bolt to it. Made a template out of cardboard, marked the holes, scribed to shape, and then cut it and drilled it. Bolted the slave to it, hung it in place and then cut the pushrod to length. I combined the ‘58 pushrod and the ’76 sleeve. Had to cut about 1.5” but it fits great. Took it apart, cleaned it up and painted it.
Only potential issue I foresee is the heat from the header. I may get a starter sleeve and wrap the slave or maybe wrap the headers. My only other option would be designing some sort of cable system that pulls the fork from the rear.
Anyway, here are some pictures. I’m gonna break up the uploads to 3 posts. Seems less likely to fail that way.
Need to fit the clutch slave cylinder in there. The stock mechanical linkage won't fit because of the steering box.
With the header off it doesn't look so bad. It's gonna be tight against the steering box and I may have to move it again when I upgrade to power steering.
Specialty tools required for this job.
Forgot about the threaded holes in the block from the mechanical linkage. Gonna make this easy.
First step was to cut a piece of cardboard and make a template.
Slave hanging in place on the template.
Template cut to shape with the holes in the right places.
Back on to confirm fit and clearance.
Straight up shot from below.
Clears the headers but the heat may be an issue.
Closer view of the header clearance.
If I wrap the header or maybe the slave itself, I may not have an issue.
[I] Template transferred to the 1/4" plate.
Cut and drilled and checked for fit.
Slave attached to check for fit and alignment with fork.
Using the sleeve from the '76 so it mates with the '76 fork. Slips over the '58 rod that distance to give it room for adjustment. Will have to cut it to length. It
Need to add a second nut to lock it in place once adjusted.
Rod is cut and in place. Straight up from below view.
Plenty of clearance from the steering box.
Bead blasted and ready for paint.
Primered and flat black.
Primered and painted the slave too.
Finished product ready to mount. Looks a lot cleaner than I had imagined before I started.
Mounted in place.
View from underneath. Installed an extra nut to lock the adjustment and a spring to keep it together.
View from the bottom.
Straight down from the top view.
Side view of the finished product. Still need to address the heat from the header.
The biggest issue I ran into is the Monroe Airshocks are spec’ed at 12.75” compressed to 19.5” extended. I put them on and it felt like they were bottomed out when I tried to bounce the back. Emailed Monroe and the tech told me they have a 3” rubber bumpstop in them so they are effectively bottomed out at 15.75”. So keeping the shackle hanger flipped and using the lower stock mounts extends the shock some and will hopefully let me use them. Either way, I like the stance now.
So basically I cut one end of the ubolt plate off and welded the stock bolt on mounts to it creating a ubolt plate with a shock mount. Turned out nice and the shocks seem to have some play but I am still thinking they will bottom out too soon. Will probably have to find a shorter pair. It’s gonna ride rough but I don’t want it to bottom out too soon. Want the air shocks also because I intend to haul some music equipment in it. Anyway, here are some pictures.
If you look close, you can see the shock mount on top of the ubolt plate with a spacer hanging out of the other side. This was just mock up and I was going to make a proper spacer but don't need to now.
Basically took the two pieces in the center and cut and welded them together to make them look like the one on the left.
Turned out good but I need to take some of the angle out. I guess that is what is done for the stock height?
The other side.
Shocks nor extended more.
Other side.
Truck sits more level with the rear hanger flipped.
Is the back too low? Maybe it is just the picture. The bed is pretty heavy and will lower it more, not sure just asking.
Same color as my truck and about the same patina. Looks like all the areas I need sheetmetal are good. I may even be able to just swap cabs.
Great work so far, I love this build! And score on the extra cab!
