I've been shopping around for a good all-around dd cam, that lopes a bit at idle, but allows for towing/hauling, and has good street manners, as well as fits into the dynamic compression equation I'm looking for.
I was wondering about something concerning your cam. I know comp calls it a 260* duration cam, and that is the number you're using when calculating the DCR, but their 260 actually has more duration than the Howard's cam I was looking at, and Howard's calls theirs a 263*. So, with that in mind, how can your equation to find DCR be accurate? Maybe you'd be better off use the a 264 duration # to calculate the DCR?
Maybe that was why discrepency between your final number of degrees and that from comp?
Do you have a link to the Howard cam you're looking at?
So, I was doing some reading, and I've read several cases where people are saying that Ford 429 roller lifters will fit into a Ford 300 block just fine. There's a little grinding you have to do on the far lifter (#12 for the #6 cylinder) but nothing major. Then, you get a custom ground cam, shorter push rods and you're good to go.
I've had a negative experience with flattened lobes before, and flat tappet cams are also rather outdated. Even if I don't notice a performance gain (which I probably would), just the added durability/lifespan seems like it'd be worth looking into.
The lifters can be had used, but are around $50 a set (for two). Quite a bit more, but it seems that they can be used and reused due to not mating with the cam. I also wrote Comp and asked what a custom ground roller lifter cam would cost.
I may be chasing an idea bigger than I want to tackle, but it seems worth looking into.
I looked into this many years ago and it was going to end up costing $800-$1000 for the cam and lifters. I would love to run a roller cam set up. But I just can't justify spending that much. Let me know what you find out. If it's much cheaper then that now I'd run a roller set up.
the guy said it does lope at idle, but he sounded as though he didn't really remember it, so I was wondering what the forum members thought of it.
I am continually surprised by how many cam makers offer cams for our 300s. Unfortunately, even though I understand how cams work, the supplied numbers don't say much to me. Just the little explanations of "good low end torque/performance/economy" etc.
I guess I'll see what Comp's price is on a custom grind. If this was only a project truck I wanted to drive around on weekends, that'd be one thing. But this has been my daily driver/off-roader for 10 years now and is and will be for many more to come. It just might be worth it to me. I'll let you know what I find out.
I think the biggest problem you'll have getting a roller cam is finding someone with a steel cam blank. I know Greg and some of the others who drag race a 300 have talked about solid roller cams so the blanks exist, but who has them now and how much?
I talked to Comp about a custom grind and am waiting on them to send me a spec sheet to approve. Basically they can take any existing lobe profile and grind it onto a blank at the ICL and LSA you want.
Looks like you're right.
Originally Posted by Comp Cams
That kind of cam would require the use of a different cam core for a roller setup, and being that none have been made for that engine, we do not have any roller cam cores to custom grind one out of unfortunately.
Hello, AB. I read about your search for a good piston on the other forum. One of the members mentioned using a longer 240 rod with a chevy 350 piston, longer rod, shorter piston. And being a C..., the pistons are cost effective and plentiful!
Thanks for the suggestion on the 240 rods. I toyed with that idea for a little bit. It seems like it could be a really cool route to go, especially with taking some side load off the rods.
However, I bit the bullet and ordered a set of 6 reconditioned 65 - 68 rods so I can use the 351 pistons. My machinist found a set of 6 from one of his suppliers for $188 shipped. I'll have them outfitted with ARP bolts while I'm at it.
I think I'm going to go with these (the ones you were posting up on your fordsix thread, K).
I'm happy you found a deal on the rods. Yes, I love those pistons. For me, with the 19cc volume dish, they suit the 76cc chambers I'm targeting to achieve 8.97:1 s.c.r. (I'd have to recheck my numbers, but I believe it will mean taking another .010 off my block, to make a total of .030 off the deck).
Good luck. p.s. I believe you meant the same pistons, but sized at .030 over.
They're over 3x as much, but they're a different alloy and heat treated, which makes them significantly stronger. My "build it once / build it right" itch has me thinking.
I've even read a few posts where some argue that untreated hypers aren't even as strong as cast. I don't know what truth there is to that, but it gets one thinking.
I understand about wanting high quality. But at some point one has to draw a line. Afterall, the oem 300 will last what, 2-300k miles? How much better can we make it. I have been happy with the set of hypers I have, so I'll go with the speedPro ones and release my need for perfection. For a while I was tossing around the forged equivalent of the Speedpro hypers we mentioned earlier. They cost only (only, ha ha) $360 or $380, but have only a 13cc dish, which puts me too high with s.c.r.
I remember FTF mentioned that hypers can be stronger than forged pistons at running temps. Maybe you can ask him about it.
Yeah, I agree on drawing the line. I've had to do that a few times. For a time, I was looking into aftermarket connecting rods so I was sure those were nice and strong. If I had the money, I'd love to just go ALL out and make everything forged.
Yeah, I remember reading about the hyper pistons being stronger than forged, but I believe that was in relation to the expensive heat treated alloy ones.
