Engine Rebuild Part 2
Old Mar 6, 2016 | 03:08 PM
  #76
The Frenchtown Flyer's Avatar
Originally Posted by fljab
I am using this head with stock pistons, a little bit heathier cam, efi exhaust manifolds with the walker Y pipe, and a CL Offy intake with a 1.14 2150. Should be good in my '85 F150 4x4.
good plan
except I do not like the quality of the Walker Y pipe. Find a better alternative.
Old Mar 7, 2016 | 06:33 AM
  #77
fljab's Avatar
fljab
Originally Posted by The Frenchtown Flyer
good plan
FF, it's already bought and sitting there ready to go. I know I have to take a hole saw and drill out the add on/rear pipe, but the rest of it looks OK as far as construction. I've also plugged the O2 port.
Any suggestions for an off the shelf solution?
I was basically trying to keep costs down and the Walker Y can tie into my existing muffler/tailpipe that is still in good shape.
Sorry, Didn't mean to hi jack, but maybe this is relevant info for this thread.
Old Mar 7, 2016 | 10:59 AM
  #78
AbandonedBronco's Avatar
AbandonedBronco
Alright,
Got some information from the builder this morning. He measured the engine and got some real numbers. These are with Silvolite 3118H Pistons.
He's having issues finding anything much more than stock replacement. I know there are a few others that have been discussed around here. Thoughts on pistons?
These are his calculations:
Machine 0.021" off the Deck: 8.4 to 1 compression
Machine Head to 70cc chambers (with 0.021" off deck): 8.7 to 1 compression
Zero deck block with 70cc head chambers: 8.8 to 1 compression
Base Engine Input:
Bore - 4.030"
Stroke - 3.980"
Rod Length - 6.208"
Deck Height - 10.000"
Chamber/Piston Inputs
Chamber CCs in Head - 74.4
Piston Design - Dish Top
Piston Dish CCs - 25
Gasket Thickness - 0.048"
Gasket Bore Dia. - 4.17"
Deck Height Clearance - 0.026"
Piston Ring Depth - 0.266"
Piston Top O.D. - 3.985"
Compression Height - 1.778"
Old Mar 7, 2016 | 05:16 PM
  #79
AbandonedBronco
So, looking around, I found that Mr. Gasket sells a high performance head gasket that has a thickness of 0.038" instead of the stock 0.048".
As little as that seems, it would bring the compression up from 8.77 to 8.94.
Old Mar 7, 2016 | 05:40 PM
  #80
BaronVonAutomatc's Avatar
BaronVonAutomatc
I used these pistons: Speed-Pro Hypereutectic Pistons WH674P - Free Shipping on Orders Over $99 at Summit Racing the compression height is slightly different but nothing that can't be milled away. They also use shallow rings so a bit less friction. I measured one and the dish is 25cc.
Old Mar 7, 2016 | 05:45 PM
  #81
fordman75's Avatar
fordman75
I would go with the Fel-Pro 1024. It's a better gasket and has a compressed thickness of I think 0.039". So it's accomplish pretty much the same increase in compression as the mr. gasket one.
Old Mar 7, 2016 | 05:54 PM
  #82
AbandonedBronco
Works for me. I've always had good luck with Fel-Pro.
I think 8.92 would be enough compression for me, and I could get it with stock pistons.
That would change things to:
Volume Contribution (CCs)
Head Chamber - 70
Gasket - 8.77
Deck - 0
Piston Dish - 25
Piston O.D. - 1.24
105.01 CCs of head volume.
831.925 CCs for the cylinder.
So: (831.925 + 105.01) / 105.01 = 8.922
About a 0.9 bump from stock.
Old Mar 8, 2016 | 10:02 AM
  #83
seattle smitty's Avatar
seattle smitty
I put this link on FordSix, but it should be here too. My auto machinist of many decades has been telling me that the new parts he gets anymore are often cr@p.
The late Joe Mondello was one of the best and busiest builders of racing and hot rod engines.
mondello.com - Machine it, Blueprint it, Professionally build it
Old Mar 8, 2016 | 03:47 PM
  #84
AbandonedBronco
Thanks for the link seattle. I think that's a good point on machine trueness. I think we just automatically assume that all of their equipment is all within spec. If we're giving them $1000s, we should have every right to ask.
So, here's a thought:
How difficult (or expensive) is it to bush pistons? 351w pistons have a wrist pin of 0.912" whereas mine are 0.975". If I were to bush it down to 0.912", I'd have a whole range of options opened up.
Keith Black KB Performance Pistons SKB379-030
Those right there would bring me to ~9.2:1 compression with only having to true up the head/block, which would prevent me from shaving off too much material.
Thoughts on this?
Old Mar 8, 2016 | 05:57 PM
  #85
Mtphammer's Avatar
Mtphammer
Thoughts on this?
I know the Frenchtown Flyer has recommended that method before, but I am unsure of which application he was referring to at the time (full race, daily driver, etc.)
Old Mar 8, 2016 | 06:47 PM
  #86
BaronVonAutomatc
Bushing pistons is pretty easy, and would indeed open up a lot more options.
Speed-Pro Hypereutectic Pistons H653CP30 - Free Shipping on Orders Over $99 at Summit Racing
These are a little shorter and have a slightly larger dish so you would have to machine the block more but they're lighter. Looks like they would give pretty good squish with a 300 head too.
Old Mar 9, 2016 | 10:16 AM
  #87
AbandonedBronco
Those look like they'd be about perfect. I plugged them into the numbers.
Head Chamber - 72
Gasket - 8.77
Deck - 0.023
Piston Dish - 19
Piston O.D. - 1.24
That's with the 0.039" gasket. Shaving the head to 72ccs, and decking the block down to 9.97", which leaves about 0.009" above the piston (with the 1.765" piston height).
101.033 CCs of head volume.
(831.925 + 101.033) / 101.033 = 9.234
I would think 9.2 would be about as high as I would want to go, since it would still be regular pump gas and not too excessive, but would definitely be a noticeable kick in power.
Thoughts?
I'll ask the guy about bushing the pistons. However, in this case, wouldn't he need to bush the rods, not the pistons?
Old Mar 9, 2016 | 03:44 PM
  #88
6978sghfbjklgdfsjhkl's Avatar
why don't you ask him to
Head Chamber - 72
Gasket - 8.77
Deck - 0.023
Piston Dish - 19
Piston O.D. - 1.24
Thoughts?
fit your rods for floating pins..steel on steel..?
http://speedtalk.com/forum/viewtopic.php?f=1&t=23097
that'l wake him up..
Old Mar 9, 2016 | 06:11 PM
  #89
AbandonedBronco
Putting this here for later reading, as well as for others. Good stuff.
Engine Building Mistakes - Mustang & Fords Magazine
Old Mar 10, 2016 | 10:33 AM
  #90
You do not need to bush the pistons. You need to bush the rod down to .912 using Sealed Power bushings, similar to these:
Sealed Power Pin Bushings 2304V - Free Shipping on Orders Over $99 at Summit Racing
