I have developed yet ANOTHER problem!
Old Feb 10, 2016 | 03:05 PM
  #121
351Cleveland C4's Avatar
351Cleveland C4
What about the one mentioned above? The 71 CJ cam?
Old Feb 10, 2016 | 03:17 PM
  #122
JEFFFAFA's Avatar
JEFFFAFA
Don't forget the NOS 72 CJ cam that's available. As far as I know factory Ford cams don't have to be Broken In. You would just have to advance the cam to bring it back to the 71's specs.
Old Feb 10, 2016 | 03:19 PM
  #123
MIKES 68 F100's Avatar
MIKES 68 F100
I''ll run it tonight , DD5 is on my Laptop at home
Old Feb 10, 2016 | 05:09 PM
  #124
351Cleveland C4
Here's a better picture of the lifters. Some are worse than others, but all these are junk. The cam lobes look about the same.
On a positive note. I now have 3 junk camshafts. Anyone have an idea what I could make with them? Some kind of cool garage art?
Old Feb 10, 2016 | 05:10 PM
  #125
Gembone's Avatar
Gembone
why wouldn't factory cams need to be broke in?
Old Feb 10, 2016 | 06:12 PM
  #126
351Cleveland C4
Pulled the main caps. Main bearings look ok, about what I expected... So I think I'll just clean this baby out and slap it back in with a new timing chain and oil pump.
Old Feb 10, 2016 | 07:20 PM
  #127
MIKES 68 F100
ok I ran it you lost some HP and TQ with that cam .
Old Feb 10, 2016 | 07:22 PM
  #128
MIKES 68 F100
something like the Lunati logo ?
Old Feb 10, 2016 | 08:12 PM
  #129
351Cleveland C4
Jeez! Lost 70hp....
Old Feb 10, 2016 | 08:17 PM
  #130
351Cleveland C4
What about this cam? Crane 260
Old Feb 10, 2016 | 09:12 PM
  #131
Coastal68's Avatar
Coastal68
Camshaft stool!
Old Feb 10, 2016 | 09:25 PM
  #132
351Cleveland C4
Hmmmmmm........
Old Feb 10, 2016 | 09:38 PM
  #133
Alex from GA's Avatar
Alex from GA
I don't know about cams but a guy in my neighborhood has his mail box on a big truck crank shaft.
Old Feb 11, 2016 | 03:03 AM
  #134
JEFFFAFA's Avatar
JEFFFAFA
Made out of a different metal. Stronger. Like Chebie cams used to wear out after about 100.000 miles but a Ford cam didn't. I've never heard of a Ford tech winding an engine up to break one in.
Just looked. I have a 1970 genuine Ford shop manual. It states "18. operate the engine at fast idle and check all hose connections and gaskets for leaks.When the engine temperature has stabilized adjust the engine idle speed and idle mixture"
So you guys see, They are not breaking in the cam. simply checking all around it.
Old Feb 11, 2016 | 03:12 AM
  #135
JEFFFAFA's Avatar
JEFFFAFA
Garrett. Flat tappet lifters normally spin a tad in the bores as the engine is running. That's why normally a worn cam lobe also has a lifter with a smooth but concave surface. Yours look like the lifters were not doing that mellow spinning. Gunk in their bores? Oil or pressure related? DON'T use Penzoil! Ford Motorcraft or Valvoline my personal Favs.
As far as the old cams go, core for a custom ground cam????
