I have developed yet ANOTHER problem!
Old Jan 28, 2016 | 02:21 PM
351Cleveland C4's Avatar
351Cleveland C4
Lifter is concave, camshaft is wiped out.....
Old Jan 28, 2016 | 02:26 PM
JEFFFAFA's Avatar
JEFFFAFA
AHHHH, Huevos. Just the one lifter and lobe?
Old Jan 28, 2016 | 02:29 PM
351Cleveland C4
So far yes, just one.
At least it's not to god awful expensive.
http://m.summitracing.com/parts/sum-k5200
Old Jan 28, 2016 | 04:05 PM
Turbo Dog's Avatar
Turbo Dog
Bummer...now the hard part is trying to figure out why that failed.
Old Jan 28, 2016 | 04:16 PM
351Cleveland C4
I have a feeling that the lifter locked up solid and as such, was keeping too much pressure on the cam. I have comp cams double spring valve springs with a 125lb seat pressure. Transferred through the rocker, that's close to 250 pounds riding on the cam if a lifter failed.
I will inspect the lifter later tonight when I get home. Between work and school, I don't have much daylight left
Old Jan 28, 2016 | 04:52 PM
MIKES 68 F100's Avatar
MIKES 68 F100
oh that sucks
Old Jan 28, 2016 | 05:40 PM
351Cleveland C4
Originally Posted by MIKES 68 F100
oh that sucks
Tell me about it!
Thinking about it more. Night before last I was ripping around and hauling a$$, satisfying my need for speed and enjoying the monstrous roar blasting from the pipes. Something probably went wrong at that time, and my commute the next day did it in.
Old Jan 28, 2016 | 06:33 PM
68murc's Avatar
68murc
oh that sucks
sucks bigtime........
Old Jan 28, 2016 | 06:35 PM
JEFFFAFA's Avatar
JEFFFAFA
Maybe put a partial synthetic oil in it next time?
Old Jan 28, 2016 | 06:58 PM
351Cleveland C4
The lifter must have failed and caused this. I've been running this cam and engine for close to 20,000 miles.
I think I might start running 15-40 diesel oil for its higher detergent and zinc levels.
Old Jan 29, 2016 | 02:03 AM
CraigerF100's Avatar
CraigerF100
im no engine building guru, but if you have bent a rod and blown out a lifter, is it possible that your rods are the wrong length? or your lift on your cam is too high for your rocker and or have the wrong size rocker? like a 1.6 besides a 1.7?
im asking out of curiosity as I am building myself a motor. educating myself I guess you could say.
Old Jan 29, 2016 | 08:01 AM
351Cleveland C4
Yes that would be a very logical assumption, and in most cases you'd be right. But the geometry is good on it. I will be rechecking it when I go to put things back together.
Old Jan 29, 2016 | 08:34 PM
  #28
351Cleveland C4
I have identified the root of the problem. The hydraulic lifter is locked up solid. I put it in my arbor press and couldn't get the plunger to move at all.
For those of us that have never seen what a lifter looks like after this happens... You can see just how dished out it got. And the wear pattern created by the wiped out cam lobe.
Old Jan 29, 2016 | 08:59 PM
  #29
Coastal68's Avatar
Coastal68
Ouch! What does the cam look like?
Old Jan 29, 2016 | 09:21 PM
  #30
351Cleveland C4
Haven't pulled it out just yet, but looking through the lifter bore, the lobe is completely round...
