If you're running dual valve springs, remove the inner spring for the break-in period. Also, use GM EOS, Comp Cams or other break-in additive. I use VR1 racing oil for the zinc content. Change the oil and filter after the break-in is complete.
Other than the obvious rounded lobe, all your other lobes look pretty worn to me as well. I assume you plan to replace all the lifters with the new cam. What is your normal everyday oil you use?
Conventional 10-40. Whatever was on sale.
Originally Posted by ultraranger
Just a thought.... You could retro-fit a roller cam in the Cleveland. It'll free up some more horse power, greatly reduce friction, doesn't have to be broken in like a conventional flat tappet and it isn't prone to wiping the lobes off the cam.
I thought about it. But for right now I'm just going to replace it with the same thing.
I'll be using conventional 30wt with the Lucas break in additive for the first run. After that I'll be running 15-40 diesel oil from now on.
New cam and lifters showed up today. I got the shaft greased up and slid in the hole and the timing set reinstalled.
Also got the timing cover cleaned up and repainted quickly, as well as the new (not rebuilt) water pump. (Old pump was beginning to leak out the weep hole and was pretty rusty)
So I'll try to get some more done tomorrow if I have a chance. But I'm shooting to have it running again on Wednesday.
Got it together and fired up. Had to fix the timing first though. I was a little off.
Anyway, start it up, rev it up, and there's coolant blowing everywhere.... From behind the Timing cover.... Wonderful....
So I'm taking it apart again....
Stuff like that's aggravating. I learned my lesson a long time ago, when replacing a water pump or removing the intake or heads, not to (initially) fill the system with anti-freeze/coolant after everything is put back together.
I just fill the system with water and check for leaks. If no leaks, I'll fire the engine up and let it get up to operating temperature while still checking for leaks. After it gets up to temp, I'll shut the engine off and then let it come completely back down to ambient temperature. If still no leaks, I'll dump that water and THEN I put the coolant/water mix in.
Straight water is cheaper to dump, if you have a leak after reassembly, than to lose your coolant.
With any luck, it won't take you too long to get it re-redone.
Another reason to use water: no methods of "proper disposal" are needed. I usually take that opportunity to flush the system out, though. If it's running great with no leaks, then drain a little of the water. Mix up some Cascade with some new water and pour it in the system. The cheap and easy way to flush the cooling system.
I've been doing a lot of reading about oils and cam shafts and whatnot. I've found out a lot of things. This particular page has a TON of information about engine oil and how over 170 different oils stack up against each other.
Be Speedy or in a hurry to get it back on the road is not a virtual thing of doing it slower and make sure it's done right the first time that is sometimes hard to learn.
But we'd all been their a few times young or old over looked things.
And assuming the rear new water pump rear plate cover bolts are tight can lead to having to pull the pump again. Something we learn as a young man or in are youth.
I once left off the valley cover under the 390 intake for 15 yrs. with no bad effects of burnt sludge built up on the under side of the Iron intake..
I carried that valley pan in my camper for yrs waiting for the day I'd have to remove it to install in. At 97k I pulled the engine down to get the heads rebuilt with harden seats.
And install a RV low end TQ cam.
Orich
Orich
I read that entire article about oil. Very good piece. My brother worked at an oil analysis lab at CAT for many years. He concurs completely. And I know just what the authors talking about on the MUST HAVE MORE ZINC myth. I helped a guy put a new engine in yacht, and all the owner talked about was adding zinc to the oil to break in the camshaft. So I asked him, "how do you know when it's got enough zinc in the oil?" He turned his head like a puppy (when he hears a new sound) and told me to just add some. He blew that 454 up on his way to Alaska. I guess two qt.s wasn't enough.
