Here's food for thought. How about a Ford factory hydraulic cam that doesn't need breaking in as far as I know? According to Ford Performance book by Pat Ganahl the best 351C cam was the 71 CJ cam which had the same profiles as the 428 CJ. 270/290 degrees duration,.481/.490 lift. Part number D1ZZ6250A. Now I can't check the Ford Dealer Parts locator but I can the other two. Nobody has it. So going back in the Ford Performance book it says the second choice is the 1972 351CJ cam. Part number D2ZZ6250B. This has the same profiles as the 71 cam only it is indexed 4 degrees retarded. So advance it back those 4 degrees with a multi index timing chain and sprocket set. This places show this cam.
That grind is available aftermarket from sealed power, P/N CS-650. And from Howard's cams p/n 237211-15.
But I'm quite fond of the 282/292, 486/512 cam that I've been running. Strong, smooth, high vacuum, and good thunder from behind.
If those specs fit what you want then I say stay with 'em. I was just throwing out food for thought Garrett. You know me, I like to come up with things most don't think about. Kinda like thinking outside the box.
Indeed Jeff! Indeed. I listed those part numbers for future reference.
When I was building the motor the first time I was considering the CJ cam. But then I found mine and liked the specs. So I went with it. Glad I did. Couldn't be happier with it really.
You're probably all over this, but, check the timing chain and gears before re-installation. The sometimes abrupt jerking, stopping and starting with the cam/lifter issues can stretch the chain and/or damage teeth.
Engle part #3110h
Powerband 1500-5000
Low end torque, street & towing.
8.5 - 9.5 compression.
Valve lift IN .510” - Duration 262° - Cam lift .295” - 112° Lobe center
Valve lift EX .510” - Duration 270° - Cam lift .295”
It idles a bit rough but I'm getting nearly 20" of vacuum.
I utilize 14 degrees of initial timing with the Distributors 20 degrees of mechanical.
I am also using a Crane Adjustable Vacuum advance unit and my Carb has been built by the best. (a Holly 4150 by Performance Carb in Ontario, Ca. NHRA)
The old boy has a Limited Slip Dana 60 Rear End and I need to be very easy on the throttle leaving a stop light. I have shifted at 5200 and it is still pulling.
Oh yea...ALWAYS replace timing chain and gears when replacing the Cam. (Unless they are BRAND NEW)
Good chance your main bearings will have issues to with that much metal in the oil.
Hope you get it all worked out man. And use a high zinc oil for break in ..
I'm going to be pulling them main caps and rod caps this afternoon and looking at that situation.
If this was mine it would be getting a complete rebuild. That metal is in the oil galleys, too.
Galley plugs should be removed and galleys brushed out. Cam bearings have to be toast also. Crank journals should be measured if the wear isn't obvious.
