Lets see those 5th wheels
Old Jan 29, 2018 | 02:42 PM
  #1531
System's Avatar
System
Prolocutor
Originally Posted by rvpuller
Is that Mor/Ryde suspension, I have old style Mor/Ryde RE mounnted directly to the frame that uses the same rubber springs as the IE uses so no broken equlizers here. The photo isn't the best and some of the trim was missing because I was repairing tire damage at the same time.
Don't you love the way the disks stop
Denny
Yep Denny, it's the MorRyde setup. Had it done last summer after my Equaflex equalizers started to crack on me one at a time. My drum brakes weren't the best with various wiring issues from time to time. The discs are just phenomenal though. With my garage full my rig can push 20k so it's nice to have it pulling back on the truck instead of pushing forward on it...
Old Jan 29, 2018 | 09:11 PM
  #1532
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Originally Posted by GIGGER
Denny if you haven't tried the new brakes yet,
watch it doesn't throw you out the windshield, LOL
This is my 3rd year with them and they will stop the truck if needed
Denny
Old Jan 29, 2018 | 09:24 PM
  #1533
rvpuller's Avatar
rvpuller
Originally Posted by cay5628
Denny, May I ask what brand your disk brake conversion is?
-Mark
I used 13" Kodiak brakes and a line set kit from etrailer, the Dexter actuator it bought from Eastland Marine because of price.
If you are going to do it yourself be sure and figure out what axles you have. I have 8K Dexter Nev-R-Lube axles with a 4 bolt flange with 1/2 bolts and 7K springs, the 7K axles have a 5 bolt flange with 3/8 bolts, if you have Lipert axles do some checking. Do some checking before you order, it's not that hard to install with a little mechanical skill, if you need help just ask.
Denny
Old Jan 29, 2018 | 09:31 PM
  #1534
rvpuller's Avatar
rvpuller
When I looked at the photo and it had the added subframe it looked like a Mor/Ryde install.
Denny
Old Jan 30, 2018 | 02:01 PM
  #1535
cay5628's Avatar
cay5628
Denny
Thanks Denny,
I'll check it out.
-Mark
Old Feb 9, 2018 | 05:44 PM
  #1536
fords/harleys's Avatar
fords/harleys
Old Feb 9, 2018 | 06:48 PM
  #1537
Effies 56's Avatar
Effies 56
Originally Posted by fords/harleys
Very nice looking truck and 5th wheel. I like the color match too. When was this taken? Looks like a fairly open camping site?
Regards,
Chris
Old Feb 9, 2018 | 07:32 PM
  #1538
fords/harleys
It was in mid October in central Wisconsin. It was our first time at this campground. They have more secluded spots too.
Old Feb 11, 2018 | 03:34 PM
  #1539
godsend1's Avatar
godsend1
Old Feb 12, 2018 | 09:47 AM
  #1540
2004SD's Avatar
2004SD
Originally Posted by scraprat
2004SD I like the Cameo but then I'm baised after owning 2 Cameos with the current being 2010 34ck3. It looks a little nose high and if bothers you look at the rear springs where they mount you might be able to lower the mounting and gain 1-1.5" in rear height.
After looking it over this weekend i decided to take your advice. There were holes in the spring mounts and the center mount for both axles which would raise the camper by 2 inches, although I was a bit intimidated by doing it, I brought the big jack and stands home and got it done yesterday afternoon. It now sits ever so slightly front high, within the bubble however, so by the time we get water loaded etc. it should be level. I feel much better about it thanks for the advice.
Old Feb 17, 2018 | 10:28 AM
  #1541
scraprat's Avatar
scraprat
Top Answer: 5
Anytime, Enjoy.
Old Feb 17, 2018 | 11:19 AM
  #1542
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Can't wait to get on the road with mine next month!
Old Feb 25, 2018 | 11:08 AM
  #1543
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Beach campground for the next 8 days... 150 yards at the most from the ocean with 74 degrees and sunny.
Old Feb 25, 2018 | 11:18 AM
  #1544
BCM's Avatar
BCM
Awesome. Where at?
Old Feb 28, 2018 | 07:52 PM
  #1545
zippododa's Avatar
zippododa
Trip to Northern Michigan. Ours is the black 350 with the Sprinter, and my brother from another mother is the other one.
