Psyclopse's "up from the ashes" build thread.
Old Mar 12, 2016 | 05:20 PM
  #196
Psyclopse's Avatar
Psyclopse
Just to verify... the port on the back of the elbow (right above the IAC) goes to the purge solenoid, right?
Spent half the day trying to get the "suitcase" apart from around the evaporator coil. The top of it was melted and I don't have a way to re-mount the bracket for the purge solenoid. I figured I'd rob the one from the truck, but I'm apparently missing something on how it comes apart.
Ran out of daylight, so I'll have to try again later...
Old Mar 13, 2016 | 06:16 PM
  #197
DeucesALLin's Avatar
DeucesALLin
Out STANDING.
You, sir, are a BAD MO FO.
Old Mar 13, 2016 | 08:41 PM
  #198
Psyclopse's Avatar
Psyclopse
Haha, not until I can turn the key and hear it run!
The rest of the wiring will be on it's way this week, and FedEx just delivered my brand spanking new battery cables. I still have a crap-load of fluids to buy tomorrow as well.
Getting closer!
Old Mar 14, 2016 | 12:40 PM
  #199
pgg00's Avatar
pgg00
Glad to see you are getting closer. Hope to see it running soon
Old Mar 17, 2016 | 10:11 AM
  #200
johnsonjf's Avatar
johnsonjf
Subscribing to this thread, I am very interested to see how it turns out.
Old Mar 17, 2016 | 05:22 PM
  #201
Psyclopse's Avatar
Psyclopse
The big brown truck dropped off a big box of wiring today!
Then it started raining...
Old Mar 17, 2016 | 07:55 PM
  #202
Psyclopse's Avatar
Psyclopse
Well, in between the rain, I managed to get the transmission/transfer harness installed. It's a pain in the butt when it's still installed in the vehicle, haha. No pictures on this one- it was dark, and quite honestly, it would look just like any Excursion's transmission with the harness in place.
ADVICE TIME- I did get a new (to me) harness for the taillights/tow harness/fuel tank. Mine was burned up by the engine compartment. This one would be an easy one to switch out- except for the branch to the fuel tank. Do you think I could weasel my hands up in there to unplug the old and plug in the new, or would it require a tank drop? Another option would be to cut the wires where I can reach them and then splice into the new harness, but being under the vehicle, I'm not sure I really want to do that.
Old Mar 17, 2016 | 11:29 PM
  #203
Bently_Coop's Avatar
Bently_Coop
Do you have a small bore scope camera or similar inspection camera for when removing the harness on the tank? If you do end up dropping the tank it would be a perfect time to upgrade the bolts on the hitch for the higher capacity.
Old Mar 18, 2016 | 01:14 AM
  #204
Daru1775's Avatar
Daru1775
Awesome build
Old Mar 18, 2016 | 11:25 AM
  #205
Psyclopse's Avatar
Psyclopse
No, I sure don't.
I'm probably going to leave that harness to do last, and concentrate on the rest of the stuff for now. If I have to drop the tank, I'll probably take your advice PLUS give the tank innards a good cleaning.
Today, I'm going to figure out how to get the cover off of the evaporator and trade the cover for the one on my truck- the standoffs on top of the cover (that the purge solenoid bracket mounts to) are melted and unusable. Then I'll move on to the underhood wiring harness. I've removed a bunch of screws already and it still isn't coming loose, so I've obviously overlooked something.
I'm still debating on the PS pump- this one has had the hose off of it ever since I got it, so I imagine it has water in it. Part of me wants to suck it out and see how it does, while the other part of me wants to just swap it over from the truck and be done with it.
Old Mar 18, 2016 | 11:29 AM
  #206
Psyclopse's Avatar
Psyclopse
Has anyone used the Dorman hood latch cable? I found it on Rock Auto (listed under "Interior" for some reason). I'm just wondering if it fits and operates right with no slack.
Old Mar 18, 2016 | 07:20 PM
  #207
Psyclopse's Avatar
Psyclopse
Today's progress-
I finally got the evaporator cover off and swapped it with the one on my truck. With the rear AC lines, I ended up having to remove the inner fender to get to all the screws (didn't have to do that on the truck). Once I got the replacement mounted, I attached the harness from about the middle of the firewall, then all the way through the passenger side (so I can start mounting stuff).
Installed-
Purge solenoid and bracket
Cruise servo
Starter solenoid
Washer tank
Battery tray
Brand new battery cables
Passenger side lighting
Plugged in everything on the passenger side
The only things I have left to do on the passenger side is put the inner fender back in, remount the vacuum tank and hook the vacuum lines back up.
Old Mar 19, 2016 | 12:37 PM
  #208
Psyclopse's Avatar
Psyclopse
Not so much a progress picture, but still exciting to me at least- the Excursion is now LEGAL.
Old Mar 19, 2016 | 04:27 PM
  #209
Bently_Coop
Getting there. Excellent work. Any pictures?
Never used the Dorman hood latch cable. For the P/S pump there is seal kits available.
Old Mar 20, 2016 | 01:09 AM
  #210
Psyclopse's Avatar
Psyclopse
No pictures yet- I was hoping to get the wiring buttoned up today before I took a progress pic, but it didn't happen.
I did get the vacuum tank from my 99 figured out (remember, I mentioned that it had four ports as opposed to the Excursion's original 2-port tank). Turns out, it is two separate tanks in one. I just took a short piece of vacuum hose and looped the lower tank closed to keep debris out of it.
Wiring didn't get done because the harness I am using had the wiper motor wires cut. In hindsight, I should have addressed that BEFORE I started hooking it up.
I did have those wires left over in my pile, and it looks like I'll only have to solder 2 of the wires, and the rest I'll run all the way back to their connection points.
