Psyclopse's "up from the ashes" build thread.
Old Feb 21, 2016 | 04:24 AM
  #181
pgg00's Avatar
pgg00
Hopefully you get it going soon
Old Feb 21, 2016 | 04:49 PM
  #182
Bently_Coop's Avatar
Bently_Coop
For your vacuum line issues I would suggest starting a Engine thread in the V10 section. There is a member who is currently going through rebuild and his thread may be of some help.
Old Mar 1, 2016 | 12:35 AM
  #183
Psyclopse's Avatar
Psyclopse
Still in wiring hell... but making progress!
Old Mar 1, 2016 | 09:10 AM
  #184
TheBigBee's Avatar
TheBigBee
Did any of that harness help you?
Old Mar 2, 2016 | 03:45 PM
  #185
Psyclopse's Avatar
Psyclopse
Yeah, it helped quite a bit. I had the harness 95% built (using most of what you sent) and I was double-checking it with a multimeter as I went. I was doing all this on the front porch!
I started losing daylight, so I put all my harness bits, multimeter, soldering iron, shrink wrap and wiring tools into the plastic tote I've been using and stuck it in the Ex like I normally do.
Then, the reality of living in a trailer park crept up and slapped me in the face- some (insert curse word here) decided to break into the Ex and swipe the whole tub. I don't know why they just didn't take the tools- seems it would be easier to conceal than carting off a big plastic tub. I've been checking the dumpsters regularly hoping they threw out the harness, but no luck so far.
I've been trying to cobble together something out of my other tub (the leftovers from the harness I *was* building), but it's not looking promising. The jerk ended up with a nice Fluke meter though...
HOWEVER, another member here has a complete harness that I've been considering, but didn't have the money, and then the oil pump quit in the truck, which left us without ANY transportation. The VA is stepping up with help since I'm in school, so I'm hopefully gonna strike a deal on that soon.
FAN SHROUD- after comparing measurements between my truck's V8 and the Ex's V10, I came up with a 4-1/2 inch difference. So, I took that amount off of the V8 shroud and it seemed to work great! I did the same thing with the upper radiator hose.
Besides wiring, I think the pressing issues now are finding a throttle body and figuring out the vacuum lines (which are radically different on the truck). You can't really re-route the hard plastic lines very easily.
Old Mar 3, 2016 | 01:20 AM
  #186
pgg00's Avatar
pgg00
That sucks about the wiring harness.
Old Mar 3, 2016 | 07:47 AM
  #187
TheBigBee's Avatar
TheBigBee
Dang sorry man that sucks. I have been in that situation you wonder what is going through their heads with some of the weird things they take.
Old Mar 6, 2016 | 11:54 AM
  #188
Psyclopse's Avatar
Psyclopse
Just a progress photo to get by while I'm still sick...
So far, I went from this:
To this:
Most of the plastic parts came from my 99 SD. I didn't really want to pillage the poor truck, but I need wheels. The vacuum tank (from the truck) has two pairs of ports, where the melted Excursion tank had one pair of ports. Anyone have any insight? Can I just cap off the pair I don't need to use?
Also, the truck's plastic vacuum lines don't come close to working on the Ex. Things are in different locations, and there is more lines for the truck, since it has EGR and all. I may have to go all old-school and just make up some rubber vacuum lines for now.
The photo below goes with my questions about vacuum ports. To my understanding, this only applies to those with the aluminum throttle body elbow...
Does the port circled in red go to the PCV valve on the passenger valve cover?
Does the port circled in yellow go to the brake booster?
Does the port circled in green (under the yellow) go to the plastic vacuum lines?
Old Mar 9, 2016 | 07:31 PM
  #189
Psyclopse's Avatar
Psyclopse
I picked up a throttle body today. It came with the elbow part that bolts to the intake. It came off of a 2000 Excursion Limited (same year as mine)- BUT THE ELBOW PART IS DIFFERENT.
BOTH are aluminum, but the one I bought has the port for the PVC down under the throttle body. Mine has it on the side, next to the other two vacuum ports. The new one doesn't have the coolant fitting with the PCV port, mine does.
Either way, the actual throttle body is the same.
I'd be curious to know the pros/cons of each setup.
Wiring will be here soon!
Old Mar 9, 2016 | 07:39 PM
  #190
pgg00's Avatar
pgg00
Anyone in the V10 section help you out yet?
Old Mar 9, 2016 | 09:27 PM
  #191
Psyclopse's Avatar
Psyclopse
No, not yet. I've had no luck googling it either. Nothing on Shop Key Pro either, other than a partial diagram that doesn't seem to even go to this engine.
What I really need is for some generous fella with a non-egr V10 to draw me a pretty picture.
Also noticed that there two vacuum lines coming from the heater box area, where there is only one on my 99 F250. Black tube on both vehicles, an additional white one on the Ex.
Old Mar 10, 2016 | 09:17 AM
  #192
ExxWhy's Avatar
ExxWhy
I'm pretty vague on exactly what you need to see, but here's a few pics. If you want to know where a particular hose or wire goes to, let me know and I can look closer. I can also take more/other pics if it helps. FWIW, mine is a 2000 XLT, 2WD.
Old Mar 10, 2016 | 12:23 PM
  #193
Psyclopse's Avatar
Psyclopse
Those images help me A LOT. Thank you very much!
It also helps that your is a 2WD for purposes of figuring out vacuum lines. I'm not replacing the melted ESOF lines as I have manual locking hubs, so no use muddying up everything wit ESOF lines.
My main question now is the lines I have circled below. It's multiple small lines connected to the one port. I just need to know where the individual red lines go.
Old Mar 10, 2016 | 12:38 PM
  #194
Psyclopse's Avatar
Psyclopse
Also...
Old Mar 10, 2016 | 07:01 PM
  #195
ExxWhy's Avatar
ExxWhy
There are 3 red vacuum lines in the circled spot. One goes to something mounted on the back of the engine, an actuator or valve for what I don't know. The second goes to the evap valve which is just to the left of the red circle with the green cap in the picture. The third line goes to the canister.
On your second question, you have the black and white lines correct.
In your question up the page a bit, I think you can see where the brake booster and pcv lines go on the throttle body.
Speak right up if you need a pic of anything else.
