Gloria: OBS build thread
Old Mar 23, 2015 | 08:38 PM
  #226
rusty1161's Avatar
rusty1161
Originally Posted by Krause
Yepp, pretty down about it. . Oh well, its only 300 bucks. Worst things have happened. But it sucks.
I have a Spectra plastic tank radiator in good shape and the Mishimito box to ship it in. PM me if you're interested.
Rusty
Old Mar 23, 2015 | 08:59 PM
  #227
DIYMechanic's Avatar
DIYMechanic
Shucks. That's a kick in the nads...
Sorry to see that happened. Did you have that same radiator in there before this round of upgrades or was this the first trip out with this combination of parts? I'm just curious what could have caused this little incident to occur now. I guess better now than on the way to RRE or something!
Old Mar 23, 2015 | 09:33 PM
  #228
Krause's Avatar
Krause
Originally Posted by oldbird1965
Just curious, did it leak after it got hit?
Yep, definitely leaked after it got hit, Front of truck got a nice shower.
Rusty
Thanks Rusty, I have my original stocker still at home so im good I think. Just sucks to go back to stocker after having the fancy mishimoto in there.
I installed radiator last summer, with that fan. Didnt have an issue with it before. But I think a combination of the extra ponies, as well as a bit of bucking up near the rev limiter when a couple bubbles of air were going through caused enough movement to do it.
Old Mar 23, 2015 | 09:35 PM
  #229
DIYMechanic
That sucks man. If it was just one or two cores (which it appears to be), a good radiator shop may be able to just crimp off and seal those couple cores and then you'd be good to go. You never know until you take it in and let them look it over.
Old Mar 23, 2015 | 10:27 PM
  #230
Krause's Avatar
Krause
Thanks Nate. I guess I bring it in and see if they can do anything about it before I get to spending money again.
Old Mar 24, 2015 | 10:27 AM
  #231
Krause's Avatar
Krause
Well talked with a radiator specific repair shop this morning. They are about an hour away, so I sent them a bunch of pictures so see if the figure they could fic it. Guy thinks hes 90% certain they can sort it out. So running it in after work today and hopefully it can be patched up.
Old Mar 24, 2015 | 11:40 AM
  #232
cowmilker08's Avatar
cowmilker08
Good luck! That really sucks man. But like you said, it could be worse.
Did you have overheating issues? I'm just curious because these engines don't have a tendency to run hot.
Old Mar 24, 2015 | 11:52 AM
  #233
Krause's Avatar
Krause
Nope never had an overheating issue. Just like fancy all aluminum radiators haha
Old Mar 24, 2015 | 12:10 PM
  #234
cowmilker08
Well, I don't blame you there, haha.
Old Mar 24, 2015 | 06:04 PM
  #235
Bonanza35's Avatar
Bonanza35
Most radiator shops can't fix aluminum, I'd ask the company you bought it threw and have them repair it.
Old Mar 24, 2015 | 06:49 PM
  #236
ReBilld's Avatar
ReBilld
Truck turned out great Andrew! Nice job Sucks about the radiator though. I doesn't look like it should be too hard to fix for a good radiator shop.
Old Mar 27, 2015 | 09:19 PM
  #237
ProjectDually's Avatar
ProjectDually
JB weld, and aluminum foil with more JB weld covering the edges of the AL will get you down the road for a little bit. A mechanic buddy of mine told me that trick. That's as long as it's not leaking through the fins I guess.
Old Mar 29, 2015 | 02:44 PM
  #238
Krause's Avatar
Krause
Yes, Im really looking for a permanent fix. Radiators are something I dont carry a spare of, so if the shop isnt going to guarantee if 99.99 percent, I'de sooner put the stocker back in or pony up for a new one.
Quick request guys:
I put projectors in this truck with some housings I thought would be super nice based on some previous reading. Long story short, I'm wanting to go back to stock style lights. I dont know why but I just prefer to look of the stock setup on these trucks. I had to trim the stock headlight chrome bezel piece to get the one-piece upper housings in. So now I need some stock replacements to go back. Does any one have some extras kicking around? I dont want poorly fitting LMC stuff, but if someone has a pair of Ford pieces around, I'de rather buy from someone on here than new from ford. Thanks guys!
-Andrew
Old Mar 29, 2015 | 06:12 PM
  #239
martin72's Avatar
martin72
I got new one from Ford Andrew they was not bad 35 a piece one is more than the other.
Old Mar 29, 2015 | 06:17 PM
  #240
rusty1161's Avatar
rusty1161
$35 for Ford headlights?
Rusty
