Gloria: OBS build thread
Old Apr 6, 2015 | 07:46 PM
  #271
fordman67's Avatar
fordman67
Originally Posted by Krause
Gear head does use the MAP, that is the issue. He says they can not just cut it out becuase it would cause issues for the truck going to different elevations and such. But it seems when the MAP sensor gets crammed with way more boost than it is supposed to, it starts getting messed up and does weird things.
Read it here
https://www.ford-trucks.com/forums/1...ost-huh-2.html
Iol I misread that up further. I was scratching my head that I read they did write it out...I was at work frustrated and needed a getaway for a min and misread it...duh lol
Old Apr 6, 2015 | 07:47 PM
  #272
fordman67's Avatar
fordman67
Somebody needs to figure out how to use a gm map that's good for 3bar.that's what I had on my old blower mustang for the piggyback efi controller. I could tune from the drivers seat real easy...
Old Apr 6, 2015 | 08:11 PM
  #273
ReBilld's Avatar
ReBilld
I agree with some of the others Andrew. I would check the MAP. Since it doesn't do it in other tunes, then that leads me to think that the higher HP tunes are boosting hard enough to throw the MAP off. I would start there, and talking to the tuner.
Old Apr 6, 2015 | 09:38 PM
  #274
Bonanza35's Avatar
Bonanza35
I think Matt@gearhead use to sell a map that read better then the factory map sensor. Mitt want to ask him. Cory put one on his truck some time back.
Old Apr 6, 2015 | 09:44 PM
  #275
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
An easy way to tell if this is your problem is to grab a compressor regulator and plumb it into the map Lin with a max of 20-25 psi. I did that on my truck and it seems to work perfect. If you have a regulator around toss it in.
Old Apr 7, 2015 | 09:08 AM
  #276
Krause's Avatar
Krause
Originally Posted by 427 fordman
FWIW Andrew, I have a boost fooler on mine, and had that bucking with it. NOT saying the map isn't part or most of your problem, just saying..
Have you gotten to the bottom of your bucking Darin? Or are you still chasing it?
Originally Posted by stainlessstroker95
I have not found a need for a boost fooler on my truck fwiw. I have also found it weird that the t500 runs out of oil on others setups. I know hybrids use less oil than others, but I have yet to throw a code for low oil.
Have you been plugged into AE Gabe? Mine wasnt throwing low oil codes. I do have an interceptor gauge, but the conditions causing that low of oil pressure (3rd gear wide open) I never glanced at it as I was concentrating on driving. I didnt even know I was killing it until a friend monitored for me. Under normal driving conditions (when I look at it), it does fine.
Old Apr 7, 2015 | 09:25 AM
  #277
427 fordman's Avatar
427 fordman
Originally my bucking was a lot worse. I then put a new melling lpop on and it improved quite a bit, but still had some at the top of a big hill, pulling hard. So I'm sure thinking that is where my bucking came from. Now that I've put the resevoir addition on I haven't tried it towing yet. I never had bucking empty, but my ones aren't as oil hungry as two's either.
Old Apr 7, 2015 | 10:22 AM
  #278
Krause's Avatar
Krause
Gosh, it's crazy a single HPOP is sucking the res dry! Especially with a melling on it. A friend ran duals on a stock LPOP with no res and never had an issue like this. Crazy
Old Apr 7, 2015 | 12:11 PM
  #279
DIYMechanic's Avatar
DIYMechanic
This is just me thinking out loud here, but if you were truly sucking the res dry, wouldn't the oil pressure light illuminate since the sender for it is threaded into the top of the reservoir? If the res is being sucked dry, the oil pressure in the res would have to go to 0 for you to do so, would it not? Isn't the sensor on top of the HPOP res the oil pressure sender (switch) that lights the light and runs the gauge?
Old Apr 7, 2015 | 12:35 PM
  #280
fordman67's Avatar
fordman67
Oil is pumped but then is in the resivour not under pressure. The hpop draws from theoretically the bottom(or close to). The resivour is just assubed to be full...I wonder..
I was reading over the weekend about the affects of a cracked pickup.the tsb stated that air entering the oil would make IPR DC skyrocket yet ICP flat line or drop. Wouldn't a resivour going dry cause similar symptoms? Its air introduced into the hpo system..
Old Apr 7, 2015 | 12:50 PM
  #281
Krause's Avatar
Krause
That is my feeling as well. Problem is, in Darin's case, what is the solution? A riffraff res extended will gain you what, 10-15 seconds towing up a hill? If you are truly sucking the res dry, a billet res extended only buys you time... At the track Im sure it sorts you out, but in the case of towing, its just delaying the fact. Thats why Im so surprised hes still pulling it dry with a melling..
Old Apr 7, 2015 | 12:56 PM
  #282
stainlessstroker95's Avatar
stainlessstroker95
I have never had it on ae, but that would be neat to see what it's doing on a hard run to compare and may help others. Hmmmm can you stack the riff raff hpop res with another one?
Old Apr 7, 2015 | 01:14 PM
  #283
DIYMechanic
Is that switch in a different port or section of the res then? I'm almost sure that is the sensor that activates the oil pressure "gauge".
I would surely think that the HPOP would be sucking air if the res went dry and then I would have thought you would see the same issues that you would when you had air in the system (funky idle, long crank times at starting, etc). So.....
You guys are the ones running these trucks, you know better than anybody what they're doing, but I just can't see stage 1s or 2s pulling the res dry with a T500 AND a HBJr. That's just me playing devil's advocate.
Old Apr 7, 2015 | 01:27 PM
  #284
oldbird1965's Avatar
oldbird1965
You mean two Riffraff extended res? I would say No. I put one on and its plenty high. Its blue below the normal gray top.
Old Apr 7, 2015 | 01:51 PM
  #285
stainlessstroker95
Ha I didn't think so, just threw it out there.
