Gloria: OBS build thread
Old Jan 23, 2015 | 11:37 PM
  #76
fordman67's Avatar
fordman67
Originally Posted by ReBilld
Sometimes it's kinda weird with him....but I still miss him
Thread officaly hijacked...
Old Jan 24, 2015 | 12:23 AM
  #77
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
show me a thread that doesn't get hijacked and I'll show you a thread with no replies
Old Jan 24, 2015 | 06:40 AM
  #78
fordman67's Avatar
fordman67
He he I didn't say it was a bad thing...
Old Jan 24, 2015 | 10:37 AM
  #79
strokin'_tatsch's Avatar
strokin'_tatsch
Lol. Most of y'all have my cell phone number, so everyone texts me the questions they want to ask me anyways. Been stupid busy at work, so haven't been able to get on here much.
Old Jan 24, 2015 | 10:11 PM
  #80
Krause's Avatar
Krause
Alright, I have a couple pictures to post. I took more but apparently the flash wasnt working and they are just black smudges. Anyways, have been working on this oil drain.
Here is the plate with fitting that will get welded in.
Here is the oil drain spout I lathed and already posted, this is how it sits in the valley
Plate sits on top, and everything gets welded together
And I also got the passenger side up pipe done and tacked, ready to be taken to friends house to get made solid. Had more pictures of that but they were all dark. BUt this is how it looks now.
-Andrew
Old Jan 25, 2015 | 05:59 AM
  #81
ProjectDually's Avatar
ProjectDually
Andrew, did you use an AN4 for that oil drain?
Old Jan 25, 2015 | 06:55 AM
  #82
DIYMechanic's Avatar
DIYMechanic
MMMmmmm. I like it. I love those Riffraff Intake Plenums. Clay does some great work on those.
Old Jan 25, 2015 | 08:12 AM
  #83
ReBilld's Avatar
ReBilld
Andrew, one thing that concerns me about that last pic is the location of the bellow, and the distance from that up pipe to the bell housing adapter. You may want to get it tucked down a little tighter to the bell housing. The way it sits in that pic it looks like you may be getting into the firewall with that up pipe. May just be the angle the pic was taken from, IDK. I try to keep them running right down along the bell housing because you are pretty limited on room right through there. Here is a pic of mine to show what I'm talking about.
Old Jan 25, 2015 | 09:18 AM
  #84
Krause's Avatar
Krause
4an will be the supply, the black fitting pictured for return is a 10an, picture must be a bit screwy..
Yea, there are a few options for plenums now, Clays are more expensive by about 80 bucks it seems, but honestly, they have the more work in them with machining and such by far. Also, they oring seal made it a no-brainer in my opinion. I know people get theirs sealed up fine with grey death, but I also know several people who have had to do it multiple times to seal, particularly around the 3 inch intake because there isnt much sealing surface. Anyways, I would have done others, but these were a christmas gift so I just asked for the ones I really wanted .
Bill, well this concerns me now as well. I had a picture of jakes setup from another thread (granted its a SD kit) that I was really trying to reproduce.
https://cimg4.ibsrv.net/gimg/www.for...b67856b63f.jpg
^Thats why I had moved it a bit higher, and mine is even a bit higher because I wanted it roughly to same height as the other one (which is tucked up high in an attempt to get out of the way of the downpipe coming down). That last bit seems silly now, but when I was building it I wanted it to look symmetrical ..?? Hmm, well Im going to head out to the truck and take a few measurements to see how much room I have right behind the corner of that head.
At this point, I may be more willing to massage firewall when the engine comes out by an inch rather than redo the pipe set-up, what do you think ?
Old Jan 25, 2015 | 09:22 AM
  #85
ReBilld's Avatar
ReBilld
If it's not much that may be ok, but you may also be limited on how much you can take the firewall in at that particular point.
Old Jan 25, 2015 | 10:10 AM
  #86
strokin'_tatsch
My question is why does everyone keep using a plate and bolting it down to the fuel pump holes? You went through the trouble of building a custom adapter for the fuel pump hole, why not make that a slight press fit and thread the top of it. Then you just thread an AN fitting into that and you don't have to worry about that plate and that fitting sits lower in the valley and makes it easier to line up the return line.
Old Jan 25, 2015 | 10:30 AM
  #87
ProjectDually
Don't you have to worry about block pressures blowing the fitting off though if it's not bolted down?
Old Jan 25, 2015 | 10:37 AM
  #88
fordman67's Avatar
fordman67
Also if I read it right my turbo paperwork wants the drain within 20° of vertical.so as straight down as maximum possible is best.
If it was done like that and a guy were worried about it working out just build a hold down to go across old pump bosses just as an incase.
I have to get my lathe at home up and running...
Old Jan 25, 2015 | 10:38 AM
  #89
fordman67's Avatar
fordman67
Green loctite retaining compound would also make that piece dang near impossible to get out.
Old Jan 25, 2015 | 12:32 PM
  #90
ReBilld's Avatar
ReBilld
Not if it were plumbed like mine with a solid piece of pipe. It would have to lift the turbo up then. I did mine in a plate bolted where the fuel pump goes and 45* fittings lined up perfect, but the lower you could get that fitting down in the valley, the easier it would be to plumb. I may redo mine like what Travis is talking about. I'm building another one of these complete set ups, up pipes, T4 mount, and all as soon as I get time. I'm gonna be trying several different things outside the box between now and then. Might come up with something totally different and unique from any other set up......I have a few ideas already
