Good to hear Andrew! I put my adrenaline in today and my icp went back up over 3000 and the power is much better again too. Hopefully after 6 times putting a hpop in it my truck finally found one it likes!
That is good to hear Darin! Shocking to hear you weren't happy with HBJ, that a lot of coin for that thing! Are you able to return it? My ICP is being dragged down to 2000 under FULL throttle in hot tune, other than that it seems to be OK. Oh well it'll have to be Im afraid, would be able to pony up for an adrenaline right now .
I'm gonna call and have a chat with him monday on returning it... Yours must be struggling some to keep up it sounds like, but it will work for ya, just maybe not "perfect". Like anything is anyway..
Slowly working out the bugs on this truck one at a time. Just a quick question on what people are seeing for boost with their stage 2's and S366? I finally got the boost gauge hooked up. A quick 'test hit' empty and I got 39lbs for certain, could have hit 40 but I was trying to keep in straight and couldnt watch. Is this normal? Thanks guys
So how sideways was it exactly Andrew? Hard to concentrate when the rear is so out of control eh?
Haha, well.. On a dry road rolling into it, it dosnt have raw tire shredding power, at least not enough to break 35's loose on demand. But a boosted launch at anything over 5lbs will put you sideways well into second gear. My old man came into town for a couple days, and it was drizzling the first time we went for a ride so I could show him the changes; we had to wait a day cause there was no way to really show him with a damp road.
I also think there is a bit more potential to be had. I know gearhead is well known to be pretty conservative, which i appreciate. But in my race tune, at FULL throttle, there is barely a haze even right off the line. Im no coal roller don't get me wrong, but I feel like in an ALL out tune with 175's, it could probably fuel a little harder than that..?
Also need to adjust pedal sensors and such. Full throttle is 3.9 volts according to AE. Thats leaving ~0.5V on the big end as well.
I don't think you are very far off Andrew. My truck for some reason seems to boost higher than most. Unsure completely why, it just does. Travis said he usually doesn't see over 40lbs with setups like yours.
I don't usually. My Super Duty will hit 43psi with the billet 65 and 160/100s, but I have to be in my TW race tune and in the top end of overdrive to see it. My Gearhead race tune is only around 37-38psi, but I think Matt did that on purpose due to me running stock head bolts.
Well Guys,
Ask and you shall receive. Got some different tunes that I wanted to try out from Tony Wildman. I'll have a larger update, but here is some food for thought…
