The stuff isn't going anywhere soon. Has a clutch disk and pressure plate with it, but no release arm - got married to a ZF's arm to get the right leverage with a mechanical linkage, and now both arms need to be replaced as I'm going hydraulic.
Noted. I think I read that the M bellhousing doesn't fit as large diameter clutch as a 460 bellhousing, even though they use the same bolt pattern. Have to research it a bit more.....
After further research, it turns out that 460 pattern adapters require using the cummins starter, so bellhousing must be ground, leaving a hole in the side of it.
Diesel ZF adapters can be bought to use a 6.0L ford diesel starter, no grinding needed.
Granted, a NV4500 would solve all these issues.....
There is an option to use the cummins starter, but it requires grinding out a spot in the bellhousing.
I will have to research the ratios a bit more, but in the end, it will likely come down to whatever I can get at the time.
The starter choice has to be made prior to ordering the adapter. If I go with a trans that requires an adapter, I'll likely go with the 6.0 starter version, and make a heat shield above it. Less chance of liquid/dirt getting into the bellhousing.....
Yeah, I don't drive like that anyways. I have actually used a 2.3L M5OD & 3.45 rear axle ratio truck (B2300) to tow-dolly a car over 50 miles. Not something I would want to do on a regular basis, but wouldn't hesitate to do it again if the need arose. I only had to downshift for 1 hill, and that particular hill the truck won't pull in 4th, empty. I just capped speed at 55, and completely ignored the existance of 5th/OD.
I think the Ford-Cummins plate also puts it on the passenger side, under the exhaust.
Whose plates do that? Destroked still uses the 6.0 starter. They do state that there is a little grinding necessary on the bell housing, but not as much as "others". http://www.destroked.com/prod_adapters.php
That site is more geared for the 99+ trucks. Although, they do list a cummins to ford small block adapter plate....... Seems to be geared more for auto trans.
Destroked appears that way, but they do also cater to the older stuff. They used to be a little more self service friendly, but now you have to contact and inquire about older rigs. They sell the complete install kits, as well as advise what all you need to complete the swap.
I see Ford-Cummins changed their name to DCS. They got their start at Autoworld of Montana, who does full Cummins installs in whatever truck customers bring in. There is a long story with a bit of drama there, but in basic, they parted ways on not so nice terms. Anyway, Destroked came on the scene a little later, and is the plate of choice by many installers. To put the Cummins starter on that side, it will be upside down. That also is why you have to take so much out of the bell housing. The Cummins starter mounts properly on the driver side.
From what I gather, the DCS plates which use the cummins starter, retains the original location of the cummins starter. Maybe I'm wrong.....
I don't know who the boss bought his adapter from, but has used the original 6.0 starter, since that was what he took out. His truck is an 05, if I remember correctly.
Looking at their plates (460 auto only, no options for 5 speed) the starter remains on the passenger side. The area that mounts to the engine tells the story. The block is recessed into the plate.
When looking at the adapter plates, the year of the body it is going in to doesn't matter, the only time that matters is the motor mounts.
