Superchips Microtuner Now Has 3 Program Settings
Old Jul 6, 2003 | 08:38 PM
  #31
FTE Ken's Avatar
FTE Ken
Yes, you should be okay in the lowest setting though I recommend gauges for Powerstrokes, tuned or not because it tells you what's going on (combined with a boost gauge).
Old Jul 10, 2003 | 07:44 PM
  #32
PwerStroke99's Avatar
PwerStroke99
Ken,
I received my 1705 Tri Tuner but havent installed yet. I have a question that i cant remember if u answered yet or not, but will i be able to tow in the 110 HP mode if i have a 4" exhaust and new hi flow cold air intake??? if so, what is the waight limit of the item i can tow in that mode??? Thanks.
Ken Lagerquist
Fairbanks, Alaska
Old Jul 10, 2003 | 08:06 PM
  #33
FTE Ken's Avatar
FTE Ken
According to Superchips there is no towing with 110HP. I can't tell you how much you can, only an EGT gauge can tell when horsepower is that high. Personally, I wouldn't use 110HP without an EGT gauge, loaded or not.
Old Jul 10, 2003 | 08:30 PM
  #34
PwerStroke99
Well, i have the whole setup. Gauges and all. I guess if i end up towing in that mode, and the EGTs get too high or close to too high, then i stop and deprogram to 70 or 90. I dont think i will be towing in 110, but i was just curious if it is too much for the truck. Thanks for the reply.
Ken Lagerquist
Fairbanks, Alaska
Old Jul 12, 2003 | 02:30 AM
  #35
Fordman4x4's Avatar
Fordman4x4
I have a 1700 right now but i'm thinking of getting the new 1705. One question though, i'm about to do a lift and tires (36") on my truck. Can i reprogram the speedo with the new mircotuner, if not what other options do i have...
thanks
Nelson
99 F350 SD PSD Auto
Old Jul 12, 2003 | 11:11 AM
  #36
FTE Ken's Avatar
FTE Ken
No, it does not calibrate tire sizes.
Old Jul 13, 2003 | 08:15 PM
  #37
Luker's Avatar
Luker
It seems that with the 60 hp setting my transmission makes a thud when I take off after a full stop. Does this program change anything in the transmission that would make this happen? 2002 F-350 auto transmission PSD. It seems to go away when back to stock or on the 80 hp setting.
Old Jul 14, 2003 | 12:09 PM
  #38
bricot's Avatar
bricot
Jeff, it has a tranny line pressure boost to help firm up the shifts. I replaced the shift valve and springs in my tranny and coupled with the line pressure boost from the SCMT the shifts are very firm ( unless loaded or accelerating hard).
Old Jul 16, 2003 | 04:10 PM
  #39
taxgod4u's Avatar
taxgod4u
What happens if I lose or my kids break my 1705 while my stock program is napping inside?
Old Jul 16, 2003 | 05:18 PM
  #40
FTE Ken's Avatar
FTE Ken
If its broken or lost and you needed to restore it to stock you'd have to have a Ford dealer reprogram it.
Old Jul 17, 2003 | 06:02 PM
  #41
jdross440's Avatar
jdross440
Question Superchips Microtuner Now Has 3 Program Settings
Which is the best for the money, the new Microtuner or the Hypertech Power Programmer III?
Old Jul 18, 2003 | 12:14 AM
  #42
Ozeffie's Avatar
Ozeffie
Re; the gauges that are used in these 'loaded' F series, does any one have some pics of how they've installed these into the cabins? Considering it for mine and want to see how others have tackled it...
Ozeffie
Old Jul 18, 2003 | 12:20 AM
  #43
FTE Ken's Avatar
FTE Ken
The Hypertech does not include an OBDII diagnostic code reader. It also peaks at 50HP, 20HP lower than the Microtuner's lowest setting.
Old Jul 25, 2003 | 07:23 AM
  #44
napsterstang's Avatar
napsterstang
Hi,
I purchased the Microtuner last night. Sorry for the silly question but how long do these usually take to ship? Do they have the free overnight shipping also?
Thanks,
Chris
Old Jul 25, 2003 | 08:32 AM
  #45
FTE Ken's Avatar
FTE Ken
They ship the next day, same day if they are ordered before noon. You didn't really expect free overnight shipping at the prices we're selling them for? UPS ground.
