BIG RED's build thread
Old Nov 18, 2013 | 10:59 AM
  #616
El Camino Man's Avatar
El Camino Man
Hold your mouth right and use all the right cuss words lol!
Old Nov 18, 2013 | 11:12 AM
  #617
oldbird1965's Avatar
oldbird1965
Bill, are there enough bends in the stock 3 1/2" to make the DP? I can't find anybody around here to do a 3 1/2". I don't know if my nephew took my old system to the scrap yard or not.
Old Nov 18, 2013 | 05:55 PM
  #618
ReBilld's Avatar
ReBilld
Not sure yet Glenn. I hope there is. I haven't pulled the stock system from under the truck yet.
I didn't get a lot done today. I had to stop work on the truck, and work on some of my side work.......gotta make some $$$. I did get the block flushed out and the IH water pump on though!
Old Nov 18, 2013 | 05:59 PM
  #619
martin72's Avatar
martin72
Looks good Bill, I can't wait till RRE I want to go for a ride in BIG RED.
Old Nov 18, 2013 | 06:21 PM
  #620
DIYMechanic's Avatar
DIYMechanic
That looks good Bill! Where did you get that coolant neck? It looks heavier than the cheap stamped tin ones that you generally see. Looks like the one on my old truck which had a heavy 1/4" plate base on it.
Old Nov 18, 2013 | 06:32 PM
  #621
fordman67's Avatar
fordman67
You got that right kevin!
Old Nov 18, 2013 | 07:15 PM
  #622
ReBilld's Avatar
ReBilld
We can do it!
That's the stock neck. I just painted it
Old Nov 18, 2013 | 08:46 PM
  #623
tshrager's Avatar
tshrager
What? No SD tensioner mod while you're in there?
Old Nov 18, 2013 | 10:05 PM
  #624
Joey Fletcher's Avatar
Joey Fletcher
Question??
Is no one using propane injection any more??? If not why??
It set my old truck on fire with the larger injectors...Made a ton of HP I miss it being on my truck....but I knew I could not keep running it with out a job...It would break parts...or find the weak link for sure
Old Nov 18, 2013 | 10:45 PM
  #625
oldbird1965
I used to but took it off because of the temptation of turning it up and 'finding the weak link'.
Old Nov 18, 2013 | 11:00 PM
  #626
ReBilld's Avatar
ReBilld
I would have, but that one is brand new.
Old Nov 19, 2013 | 09:52 AM
  #627
El Camino Man
From what Iv heard, theres a reason its called pro-PAIN. I guess its a pain to get it tuned right, but I also have zero experience with it. Personally, Id rather run water/meth and be done
Old Nov 19, 2013 | 11:16 AM
  #628
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Wow, Bill, you have been working hard and feeling good, congrats in both situations. I like the job in the BR.
Old Nov 19, 2013 | 01:35 PM
  #629
coreylasalle's Avatar
coreylasalle
You sure got a lot done since iv been gone, holy moly, I got some catching up to do on FTE. Looking good Bill.
Old Nov 19, 2013 | 02:58 PM
  #630
ReBilld's Avatar
ReBilld
Thanks guys.
