75 Highboy Resto-Mod Build
Old May 15, 2014 | 08:23 PM
  #196
AK FORD GUY's Avatar
AK FORD GUY
Look'n good man!
Old May 15, 2014 | 08:25 PM
  #197
TylerJ150's Avatar
TylerJ150
Originally Posted by AK FORD GUY
Look'n good man!
Thanks! Unfortunately I'm not going to be able to paint the whole truck right now since I ran out of time at school. I have to take it home tomorrow so I just trimmed it in so I can put it back together and drive it. The primer white doesn't looks too bad on it anyhow lol
Old May 15, 2014 | 10:30 PM
  #198
kevin316's Avatar
kevin316
different idea for the door handle. You should throw some primer on there to give you an idea how it might look when painted
Old May 15, 2014 | 10:39 PM
  #199
TylerJ150's Avatar
TylerJ150
Like this maybe? Lol love how it turned out
Old May 16, 2014 | 08:02 AM
  #200
Feardeere7's Avatar
Feardeere7
Looking good!! Your progress is awesome! Keep it up.
Old May 16, 2014 | 08:12 PM
  #201
yayhelicopters's Avatar
yayhelicopters
Smile Frame
Originally Posted by TylerJ150
Frame has been swapped I guess. It's too wide and the T-case is married. The cab is the original though because the VINs match the highboy code and the filler neck hole has a patch panel visible from the inside.
I have a '75 250 highboy my dad bought brand new, and it's frame is wider than most. We're thinking the factory slapped a 350 or larger frame under that body. I don't know how many leaf springs there are, as I'm not home to count them, but there are quite a few. A 75 would have what I think is called a ball and knuckle on the front end with drums, also the steering will have a gear box on top of the frame with hoses running to a slave arm. Your 460 is out of a car, I have a 429 out of Mercury Monterey and we had to trim the frame because we used the stock manifolds. (This was mentioned earlier.) Just some things to look at, also mentioned, is that the truck is close to 40 years old, so who knows what may have been done to it. Continue to make it your own and how you want it!! Good luck!
Old May 16, 2014 | 08:53 PM
  #202
TylerJ150's Avatar
TylerJ150
Here's how she sits for now. Didn't get it 100% like I wanted, but its way better than it was when I got it so I'm happy
Old May 16, 2014 | 09:08 PM
  #203
yayhelicopters
Back glass
So, has anybody on this forum done this swap? I'd prefer that smoother look with black gaskets and everything on mine. I'm getting rid of the chrome strips on the windshield, so it'd be nice to do it the back as well.
Installing Back Glass | FordMuscle.com
I have a sliding back glass in my '75 with just the black gasket. Very clean looking.
Old May 16, 2014 | 09:09 PM
  #204
TylerJ150's Avatar
TylerJ150
I'm going to go pull one from the yard here if they've got a decent one, I'd rather do that than put my old one back in
Old May 16, 2014 | 09:55 PM
  #205
yayhelicopters
Your antenna
I noticed that you filled in your antenna hole. What did you do for an alternative?
Old May 16, 2014 | 10:13 PM
  #206
TylerJ150's Avatar
TylerJ150
There's a kit in LMC that has a box you put under your dash or somewhere and acts as your antenna, I'll be getting one of those and mounting it in the roof on the passenger side, running the cable down the pillar, since the dome light and cab lights will be on the other side. I don't listen to the radio much, but it'll be there when I need it. It's only $30 or so I believe.
Old May 18, 2014 | 11:00 PM
  #207
TylerJ150's Avatar
TylerJ150
Worked on putting it back together all afternoon and took it out for a spin, always makes you want to finish it so you can drive it more lol
Love the white and blue inside, it really ties together well
Old May 19, 2014 | 05:20 PM
  #208
yayhelicopters
Is that GT steering wheel going to be permanent? Reason I ask is that I used to have one on mine, and it was such a pain in the butt to have take an extra 1.5 turns compared to big steering wheel to get to over to or close to the steering limits.
Old May 19, 2014 | 07:24 PM
  #209
TylerJ150's Avatar
TylerJ150
It's going away as soon as funding allows me to get the new 15" I have picked out. I hate the tiny gokart wheel
Old May 19, 2014 | 10:28 PM
  #210
TylerJ150's Avatar
TylerJ150
Well I did some wiring today, rewiring that is. Got everything but signals and reverse lights working properly. Hazards work, highs, lows, brakes, markers, everything but reverse and signals. I have the signals narrowed down to the switch in the column I'm pretty sure. The reverse lights however I'm not sure. I jumped a wire on the plug under the hood which is what I though you were supposed to do? I may be confusing my C6 with the manuals. They come on when I turn the key and just stay on.
Also gave the ol Eagles a much needed polishing
