75 Highboy Resto-Mod Build
Old Feb 21, 2014 | 11:17 AM
  #166
castone001's Avatar
castone001
Awesome job this far!! I am very impressed!!
Old Feb 21, 2014 | 08:57 PM
  #167
TylerJ150's Avatar
TylerJ150
Thank you!
Old Feb 26, 2014 | 09:31 PM
  #168
TylerJ150's Avatar
TylerJ150
Since I didn't have a key for my passenger door anyways
Old Feb 27, 2014 | 03:03 PM
  #169
TylerJ150's Avatar
TylerJ150
Does anybody know what this wire harness is for? Comes out with the dimmer harness and runs across the floor, and under the seat where there's another empty plug. Just wondering if its anything I think I might need, if not its going away
Old Feb 27, 2014 | 03:45 PM
  #170
ford_pickup's Avatar
ford_pickup
That is the seat belt warning system plug, 75 would not of had it but 77 and newer would
Old Feb 27, 2014 | 05:26 PM
  #171
TylerJ150's Avatar
TylerJ150
Cab is a 77 so that makes sense. Thanks for the info, going to take it out now as I won't be needing it.
Old Mar 10, 2014 | 06:12 PM
  #172
TylerJ150's Avatar
TylerJ150
Went to look at the bed my buddy had today, truck out, got a lead on another, and it was Texas gold lol very little surface rust, like 2 spots with the paint off, tailgate had a baseball sized dent, but wasn't warped like all the others I've looked at, and the inside of it had very few dents in the fenderwells or floor. The owner(wasn't home) is supposed to be getting ahold of me if he's willing to sell, fingers crossed since its the best bed I've seen around.
Old Mar 17, 2014 | 04:32 PM
  #173
TylerJ150's Avatar
TylerJ150
Update time. The front and back glass is out, got lucky with no structural rust in my window sills.
Also experienced the joy of removing the dash pad.
Looks like my glovebox was replaced in 04
Scored a trimless glovebox door, going to shave the badge and put a locking latch in
This speaker looks good to reuse doesn't it? Lol
Old Mar 17, 2014 | 08:51 PM
  #174
TylerJ150's Avatar
TylerJ150
Also, does anybody have any tips or tricks on removing the trim and vents on the passenger side?
Old Mar 18, 2014 | 10:18 AM
  #175
ford_pickup
at the point that you are at right now that whole dash will come out VERY easy, one bolt through either side, two above where the steering column bolts up, one through the parking brake assy., 5 screws at the top, and maybe one more at a support in the middle, to take the vent out turn the register to where it is completely sideways, then there are 4 tabs on the side that push in and the vent comes right out, for the trim there are nuts on the back side of the dash
Old Mar 18, 2014 | 10:34 AM
  #176
61steven's Avatar
61steven
Could you post a picture of the top of the dash with the pad removed? I really like the look of a painted metal dash like the older trucks!
Old Mar 18, 2014 | 04:20 PM
  #177
TylerJ150's Avatar
TylerJ150
Thanks I figured it out, the far right vent was pretty brittle and broke but I've got it all stripped down now. I'm not sure yet wether or not I want to pull it all the way out for paint. I might just do it though just to do the best job possible.
I've got it stripped nearly bare now
Yeah here's the best I've got right now
I'll be getting the pad recovered in a nice black leather or something with a white stitch going across the front
I got the glovebox lid done today
Should look much cleaner now once its painted
The seat must have came out of a newer truck as it had these nice lift blocks underneath all the way around lol
Here's how she sits at the end of the day. I still have some filler work to smooth up but I was getting the inside stripped so I could get a buddy inside sanding and prepping.
Old Mar 19, 2014 | 07:04 AM
  #178
lbumpers's Avatar
lbumpers
Tyler, Nice work keep it up!
You could be right about the lift on the seat, but when I was younger I put 1" spacers under my seat made out of some black teflon blocks my dad had scrapped. I did it for a little clearance under the seat for my amp. Truck was all original 1978.
I'll probably keep them in some fashion when it goes back together because I got used to the way it felt, but that depends on what the seat refurb does for the seat height.
Looking good, keep at it.
Old Mar 19, 2014 | 07:24 AM
  #179
TylerJ150's Avatar
TylerJ150
Thank you, I might see how it fits and sits without, It appeared to have had a system once but I won't be doing anything crazy with it so I probably won't need the clearance if it'll sit low on its own
Old Mar 23, 2014 | 05:03 PM
  #180
TylerJ150's Avatar
TylerJ150
The seat fits fine with no blocks, better actually, sat down into the truck better than before. I did have to fab up a linkage to tie the slider latches back together to move it. I'm going to paint the frame next weekend.
Today I'm trying my hand at dying seatbelts and so far so good! The lap belts look great. The shoulder belts are still in the mix had to concentrate the mix since they were blue but they seem to be taking it well.
