75 Highboy Resto-Mod Build
Old Oct 19, 2014 | 09:57 AM
  #316
redroad's Avatar
redroad
Originally Posted by TylerJ150
I'm not sure, if they could that's not what's holding them in anyways, it's the actual rods that have ahold of it
I read that But short of the other brutal methods mentioned the crank has zero chance coming out with them in especially without possibly scoring the bearing surface on the crank ..
Old Oct 19, 2014 | 03:56 PM
  #317
TylerJ150's Avatar
TylerJ150
Yeah that's what I was afraid of. I'll try it again in a few weeks when I have time.
Old Nov 27, 2014 | 12:48 PM
  #318
TylerJ150's Avatar
TylerJ150
Finally got around to busting this thing loose last night. Had to chop all of the rods and then punch out all of the pistons, and that was the most time consuming part. It took me about 4 hours to bang them all out. The crank is in great shape all the way around and the cylinders look good as well. Going to take a trip to the machine shop in a few weeks.
Old Nov 28, 2014 | 11:47 AM
  #319
good to doo's Avatar
good to doo
Excuse me if I,m a little slow, but why did you have to cut the rods? Great job its giving me motivation to work on my truck. thanks
Old Nov 28, 2014 | 05:36 PM
  #320
TylerJ150's Avatar
TylerJ150
The Pistons were rusted to the cylinders and we could not get them to budge for anything so I went to take it apart, but the rods had clamped the crank in place so I had to cut the rods to remove the crank and punch the Pistons out.
Today I finally found a drivers side fender liner for this thing. I could not for the life of me find one at any of my salvage yards. This was in a truck at the farm I was working on and I was told I could have it.
Old Nov 30, 2014 | 03:31 PM
  #321
TylerJ150's Avatar
TylerJ150
Took the good motor out of my broken washer jug and swapped it over to the jug I got from the junk yard with a bad motor, and cleaned it all up.
Old Jan 6, 2015 | 12:38 PM
  #322
TylerJ150's Avatar
TylerJ150
Engine rebuild is now underway. First time pulling an engine for me and I was doing it by myself so it took about 8 hours working slow and bagging and tagging everything. I'll be tearing down the block and taking it to the machine shop this afternoon or first thing in the morning
Old Jan 6, 2015 | 05:36 PM
  #323
oddfordjunkie's Avatar
oddfordjunkie
What are your plans for the rebuild- stock, mild or money pit?
Old Jan 6, 2015 | 07:44 PM
  #324
TylerJ150's Avatar
TylerJ150
Just a mild build, a nice bump up from stock since I'm in there
Old Jan 6, 2015 | 07:54 PM
  #325
TylerJ150's Avatar
TylerJ150
Found this lovely surprise in the oil pump pickup
Old Jan 6, 2015 | 08:44 PM
  #326
oddfordjunkie
A mild cam and a 0* timing set is all most people would ever need.
Hard to tell from the picture what type of material it is in order to get an idea where it came from in the motor.
Old Jan 6, 2015 | 10:59 PM
  #327
TylerJ150's Avatar
TylerJ150
A mild cam and a 0* timing set is all most people would ever need. Hard to tell from the picture what type of material it is in order to get an idea where it came from in the motor.
Yeah I'm getting a new timing set, per the recommendation of the machine shop I'm using.
It's all metal, I assume it's a bearing but I haven't gotten the block torn down far enough to confirm. I know it's not a rod bearing
Old Jan 9, 2015 | 08:03 PM
  #328
TylerJ150's Avatar
TylerJ150
Well Wednesday I finished breaking down my 460 and got it taken to the machine shop. Yesterday and today I spent installing my American Autowire wiring harness from JBG and I will say I am very pleased with it. It's super straight forward, there has only been a few minor things that stumped me, but they were easily figured out. If everything works as well as install has gone I'll say it was well worth the money.
Old Jan 9, 2015 | 09:36 PM
  #329
oddfordjunkie
How much was it by the time it got to your door?
Old Jan 9, 2015 | 09:40 PM
  #330
TylerJ150's Avatar
TylerJ150
$650 or so IIRC, I can't remember, I actually got it about 6 months ago and just now got around to doing it lol
