75 Highboy Resto-Mod Build
Old Jun 14, 2013 | 10:36 AM
  #46
impalaslayer's Avatar
impalaslayer
your entire chassis is a 77.5-9. you should be able to tell if the cab is a HB cab by looking at the rear cab mounts. highboy cabs had the mounts in farther then the later trucks, so who ever swapped the body would have had to drill 2 new holes father outboard to line up with the cab mounts on the frame.
as far as your axle, id order parts for a 78 f250. take some pics and we can identify it for sure to make sure it isnt a 60 but its hard to say from your pics.
oh and also so you know for the future if you fine another one of these you want to buy a highboy will have the following features
a 36" rear frame width
divorced t-case
cross member at the very front of the frame horns
2.5 inch wide rear leafs
low pinion front axle
ram assisted steering (hydraulic actuator of the front axle)
also, Highboys had a factory 4 inchish block under the rear springs
Old Jun 15, 2013 | 09:58 PM
  #47
TylerJ150's Avatar
TylerJ150
Had a thought today, would the lift have something to do with the tie rod? Wouldn't that have been part of the lift kit?
Old Jun 15, 2013 | 11:29 PM
  #48
SuperDuty93's Avatar
SuperDuty93
I thought they had a 34" frame? .... Or maybe I should go measure mine again
Old Jun 16, 2013 | 08:19 AM
  #49
Hyperactive460's Avatar
Hyperactive460
nope not at all. tie rod is a stock item to your truck. you either have a dana 44 ( most likely ) or a dana 60 . any parts store should be able to order you one.
Old Jun 16, 2013 | 10:39 AM
  #50
impalaslayer
you could be right, at one point i had a pic of the measurement but i deleted it, guess i better go measure again
Old Jun 17, 2013 | 12:22 AM
  #51
TylerJ150's Avatar
TylerJ150
That was my original plan until I began looking at diagrams for axle configurations and none I saw had a straight bar like I have
Old Jun 17, 2013 | 12:51 AM
  #52
montana_highboy's Avatar
montana_highboy
Nice project.
Old Jun 17, 2013 | 01:55 PM
  #53
TylerJ150's Avatar
TylerJ150
Originally Posted by montana_highboy
Nice project.
Thanks, I love the truck, it's tons of fun to mess with.
Old Jun 17, 2013 | 07:30 PM
  #54
Hyperactive460
Truck Parts and Truck Accessories 78/79 is the one you need, some will very as far as the steering stabilizer goes.
Old Jun 18, 2013 | 10:12 PM
  #55
TylerJ150's Avatar
TylerJ150
Mine looks nothing like that. I'll try to post some pics for you guys, it's kind of a pain that you can't add pics directly off the computer.
Old Jun 19, 2013 | 06:28 PM
  #56
Hyperactive460
bottom of the page, thats the one you need for your truck, i have a 78 f250 and mine looks the same as yours.
Old Jun 20, 2013 | 11:22 AM
  #57
TylerJ150's Avatar
TylerJ150
It doesn't have a steering stabilizer on it though, it's a solid bar, and my steering setup is different.
Old Jun 20, 2013 | 11:33 AM
  #58
TylerJ150's Avatar
TylerJ150
The best pics I have right now
The passenger side of the axle has no stabilizer or anything attached to the bar, it's one piece and the only piece.
Old Jun 20, 2013 | 04:16 PM
  #59
Hyperactive460
got a picture of your steering set up, as far as a stabilizer you dont need to have one, but with those large tires i would recommend it. the part is still the same and will fit your truck.
Old Jul 2, 2013 | 11:10 AM
  #60
TylerJ150's Avatar
TylerJ150
So yesterday I had to replace the bulb in one of my back marker light bulbs and while I had it off I noticed the lens was wanting to come off so I decided to pop it on off and glue it back together until its time for some new ones(they're old and brittle and still just need replacing). I noticed there's a perfect little grove there for an LED strip like what I use on a lot of my projects. So I threw some leads on a red 6 LED strip, ran the wires out the back, JB welded the holes to keep out water, and glued the lens back on. I also painted the edge of the lens to match my tail lights. I'm probably going to do them differently to look a lot cleaner when I get new ones but I like how it turned out for a little thrown together afternoon project. Let me know what y'all think.
