Should be good, I used to use it at work to seal parts (engineering assets we just needed to seal didn't care how they looked) then immediately ran them in snow without issues.
Awesome. I was just a little nervous because I've always had more luck with the weather but because this so big it doesn't fit inside any garages I have access to.
I feel you pain man, mine used to clear the top of my garage by 1/4"...now it doesn't lol. Could only get it about half way in the garage and have 3 feet of working space on either side so it wasn't worth it anyway lol.
Little updated list of what I've done/need to do/want to do
Exterior:
03+ Mirror swap
20% 3M Tint
08 tailgate with step and camera
Backrack
Suspension:
Bilstein 5100 Shocks and steering stabilizer
Readylift 4" rear block (F350 conversion)
Energy Suspension Sway bar bushings
Moog ball joints
Complete Moog drag link
Lighting:
Recon LED taillights
05 Harley headlights with h1 4300k projectors
Recon Smoked Cab/Mirror lights
LED reverse/cargo Lights
Exhaust:
SPD SS Y-pipe
Mac Flowpath muffler
Everything Else:
Door seal mod(iffy on whether it's worth it)
Kenwood Head unit, Speakers, 4 way amp
Weather Tech Floor mats and Visors
285/75R16 BFG AT TKO LRE
R1concept Rotors and Hawk LTS Pads
Fumoto f106 oil drain valve
Undercover drivers side swing case
Viper 5101 remote start
Things I need to do:
Coolant flush
Trans flush
Rear diff Fluid
Things i want to do:
LED exterior upgrades
Derale 13011 trans thermostat
Dieselsite trans filter
Dieselsite max ac kit
6.0l Trans cooler
Transgo 4r100 HD shift kit
Sound deaden interior
OBA with train horns
For the door seal mod about how much tubing did you end up using? Also what was the diameter? I need to do it because i sanded the seal where the common rust occurs from the door seal rubbing the paint off the doors and now i get bad wind noise on the highway.
This is what I bought.
50 Feet Black Rubber Latex Tubing 3/8"OD 1/4"ID (#804R) by Spearit
Only thing with it is they say that it may not be one continuous piece mine ended up being 1 44' piece and a 6' piece. Luckily I was able to work with it.
Exterior:
03+ Mirror swap
20% 3M Tint
Backrack
Suspension:
Moog ball joints
Lighting:
Exhaust:
SPD SS Y-pipe
Everything Else:
Coolant flush
Trans flush
Rear diff Fluid
6.0l Trans cooler
Hey Justin do you have pics of the retrofits against the house after you got them redone? Just curious to see how it changed, I've been debating doing this i just cant decide on how much i like the look and if i would like it better if the shroud was painted black.
You can get the cover for like $45 from www.tousleyfordparts.com, the bolts for 10 bucks or so at home depot/lowes/fastenal and the sealant at any parts store for <$8
I just put up the new pictures and video of the lights. I definitely considered the black shroud but opted for the chrome just becuase it looked more factory. I may down the road decide to paint the shroud and reflector, but for the most part i don't think I will. IMO it looks cleaner in chrome. I love the output and love how it looks, i just need to figure out what i'm doing for the grill and for the bumper and I'll be happier.
Very nice, that's what i thought leaving them chrome like yours but i think i might like them better painted black with maybe some grey to match my paint and my reflectors as silver on the sides as well. What did lightwerkz do differently than what you did originally? I was going to attempt to do it myself but if its not worth my time and effort i will have them done.
