Sponsored by: Real Truck
My 02 Build thread
Old Oct 31, 2013 | 08:25 PM
  #91
xmontex4's Avatar
xmontex4
Cool, where did you get it from and how much did it set you back if you dont mind me asking ?
Old Oct 31, 2013 | 09:13 PM
  #92
02TB250's Avatar
02TB250
I got it off of Amazon for about 160ish. I'm really thinking of getting the passenger side as well to move some stuff out of the cab.
Old Nov 1, 2013 | 02:41 AM
  #93
Bently_Coop's Avatar
Bently_Coop
That case looks good in there. I like the tail lights on the dark blue of your truck as well.
Do the lights fill the gap for the tail gate sticking out?
Old Nov 1, 2013 | 05:00 AM
  #94
02TB250's Avatar
02TB250
They do not. And from what I understand buying the 2008+ lights do not correct it either. Just the wiring lines up.
Old Nov 1, 2013 | 08:31 AM
  #95
xmontex4's Avatar
xmontex4
Thats not bad i had originally thought about getting both as well. On the recon lights if you use a 10mm deep socket on the locking pins to can adjust them like the passenger side looks like it sits close to the tail gate but the drivers side doesn't. On my truck since the paint was new it rubbed off some of the paint after a while and made a bubble that i had to fix. Might be worth it to prevent any paint damage from vibrations and to make it match the drivers side.
Old Nov 3, 2013 | 05:51 PM
  #96
02TB250's Avatar
02TB250
Monte these are the best pictures I can get off the width of the case.
Some pictures from the other day.
Behind the swing case
Gap reduced down
Old Nov 3, 2013 | 05:56 PM
  #97
xmontex4's Avatar
xmontex4
Cool man thanks! Those would work perfect for me. The lights look good man, I'm seriously debating getting a conversion done now. Does the plsce you used do conversions or do you need to buy the parts snd send them in?
Edit: just checked their site your trucks all over it man it looks nice!
Old Nov 3, 2013 | 06:33 PM
  #98
Km1210's Avatar
Km1210
The lights came out great Justin!
Your front end looks sweet.
Old Nov 3, 2013 | 06:36 PM
  #99
02TB250's Avatar
02TB250
No lightwerkz has all the stuff besides headlight housings to do the retro fit. They recommend the fxr setup but that would cost you 2-300 more for just the parts over what my kit cost. I can say that my setup is now prefect. It was very expensive but the output is ridiculous.
Old Nov 3, 2013 | 06:40 PM
  #100
02TB250's Avatar
02TB250
Thanks I think it looks much better then before.
Old Nov 3, 2013 | 08:31 PM
  #101
xmontex4's Avatar
xmontex4
How much was it to get the lights done? Also is the light output better than when originally converted?
Old Nov 3, 2013 | 09:07 PM
  #102
02TB250's Avatar
02TB250
The light output is better then when I did the retro and it was 770 for the labor
Old Nov 12, 2013 | 09:59 AM
  #103
sgtnike's Avatar
sgtnike
Man .. That truck is looking better and better! AWESOME job. Subscribing.
Old Nov 12, 2013 | 06:19 PM
  #104
02TB250's Avatar
02TB250
Thanks for the compliments. Its a work of passion, I take pride in my truck and work at making it better any way I can.
Old Nov 26, 2013 | 05:16 PM
  #105
02TB250's Avatar
02TB250
Got some much needed work done.on the truck today. Changed the transfer case fluid, oil and filter, and front diff. Also painted the front diff cover.
Question I have though. It was 30 degrees and snow/raining. Would this cause issues with the rtv skinning and sealing. We let it "skin" for about 20-25 minutes per guzzle's instructions put the cover on and tightened everything down in a star pattern and then let it set for about 2 hours before we added the fluid in. As of right now it's not leaking but I was slightly concerned I don't know how the rain will affect it
