NP 435 Transmission Color Specification
"Sally Rand" aka au natural, Dave, naked as a jay bird. Since transmissions were not visable when the hood was raised on dealers showrooms/lots, there was no reason to paint them.
But engines were painted for this reason. Warner T-86/T-87 3 speeds, T-85N 3 speed w/overdrive, T-18 4 speed all purchased outside.
The "Ford" type 3.03 3 speed all syncro was also made by Warner, as it uses some T-86 parts. Ford parts catalogs have separate parts lists for the 3.03.
Sally Rand was a fan dancer, was famous for appearing on stage in her birthday suit, waving two large feathered fans around. Look qwik, you'll get a glimpse of...
Y'all have seen these trans' many years after they were installed, as most of y'all were not born yet, or were wearing diapers when these trucks were new.
OP's truck is a 1966, my DOB: 9/9/1944. How old were y'all?
painting it clear would be good to avoid rust...warner trans had yellow stenciling of the model number on it. NP had an aluminum tag on the PTO cover on the RH side..It will have the trans mfr date, model number and Ford ID number as well as the trucks sub model it was for(F28 for example) It also has the model number on it(435).
Dont forget theres a 2nd boot on the shift lever...under the one you see from inside the cab. The 2nd smaller one is usually gone in my experience hunting for one.
- cs65
- cs65
All T18,19s and T98s came with no paint. Also the ford three speeds and warner units had no paint.
NP 435 New Process cases were factory painted with red lead. So were NP transfer cases.
I have a 4x4 435 sitting here with its original paint.
I once removed three speed from a 65 and it had a awesome Mexican lithographed eagle on the top cover! Heco in Mexico. I think it came out of an early 80s granada.
Garbz.
Garbz.
Happy B-Day ND. Thank you for all of the info you always provide! Many more to you!
