Competition swap
Old Jun 7, 2011 | 06:06 AM
  #331
Builtihtuff's Avatar
Builtihtuff
How do i add pictures oh my goodness i hate that thing.
I just like convertables, after having my jeep as long as i did, i dont know how to use a link here
my fav ranger is 1992 but i saw a 97 flare side convertable
go to google images search ranger convertable its one of the first pictures and its grey
i dont want somebkind of slammed hot rod where the whole interior is vhanged and the body panelsbare shaved abd that junk, i want the marble exhaut of a 351 clevor maybe a.super also wonder if it would fit
and a new paint job and no roof
thats all lol
Old Jun 7, 2011 | 07:56 AM
  #332
nevrenufhp's Avatar
nevrenufhp
You add pix from their link. That's how I found that tandem. click on the link that says "view full size image", then copy that link. I found you a grey one:
http://images.thecarconnection.com/s...00324873_s.jpg
But when are you gonna get started? I dont hear it running yet. On another note, a soopercharger will help bring in some lower end of the power band of the big ol 4V heads.
Old Jun 7, 2011 | 08:12 AM
  #333
Builtihtuff
Would a super help though for fuel economy ? And u and I both know that is not the damn convertible I meant lol ur humor kills me !
Old Jun 7, 2011 | 01:33 PM
  #334
nevrenufhp's Avatar
nevrenufhp
I think the Magnacharger and/or Whipple have a bypass valve to help the part throttle economy. In that case, general driving will net maybe up to .2 mpg better.
Old Jun 7, 2011 | 01:55 PM
  #335
Builtihtuff
I think I just want a aggressive cam on a 351 I don't wantto deal with a blower so let's focus on a clevor and stay away from any chargers
Old Jun 7, 2011 | 02:02 PM
  #336
nevrenufhp's Avatar
nevrenufhp
Then, back to the first clevor scenario.
Old Jun 7, 2011 | 03:44 PM
  #337
Builtihtuff
I was doing a lot of reading and heard that a after market W head will flow better than a C head on W block also the first clevor scenario how much hp can i expect ?
Old Jun 7, 2011 | 04:19 PM
  #338
nevrenufhp's Avatar
nevrenufhp
I'm aware that there's some good W heads finally out there. I'm thinking cost, kool factor, and performance. A high flow set of heads is gonna run nearly $2k. Out here, I can snag a set of 351C 4V heads for 2-500. You could also snake a deal on some used hi po aftermarket heads too. Ya never know.
Old Jun 7, 2011 | 04:31 PM
  #339
Builtihtuff
2k for heads fudge that noise now what year carb 351 w shoukd i look for and those heads i can butvnew cant i from tms
Old Jun 7, 2011 | 04:46 PM
  #340
nevrenufhp's Avatar
nevrenufhp
You said you had one in your garage or barn or something. Start there. For the top of the line, the CHI heads will deliver. A little spendy tho. You can get some remanned heads if you do a search. Also try the old standby: ebay & craigslist. Actual power numbers? Hard to say. I may venture at 4-500 at the crank. A 5.7 hemi makes 345hp.
Old Jun 7, 2011 | 05:34 PM
  #341
Builtihtuff
I have a efi one with the factory rollers thats why im trykng to sell it i want carbs
Old Jun 7, 2011 | 06:36 PM
  #342
nevrenufhp's Avatar
nevrenufhp
Keep the block! A roller cam is a good power maker. Keep that and the distributor. That saves a lot of kash. I'll have to find a particular cam to use. Things change just a little with a roller cam. They hold the valves open longer,and make more power, and in a broader rpm range than an equal duration standard cam. Dump the intake, injecotrs & all the sensors, and the heads. Somone's bound to buy that off of you. Save the lifters too.
Old Jun 7, 2011 | 07:47 PM
  #343
nevrenufhp's Avatar
nevrenufhp
Lunati 51025LUN - Lunati Hydraulic Roller Tappet Camshafts - Overview - SummitRacing.com
Have a gander at that kam. It was either that, one from Trick Flow, or the Edelbrock performer rpm. All pretty equal, and make power up to 6500. Of course, all 3 have the proper idle. Here's the other 2:
Trick Flow Specialties TFS-51402001 - Trick Flow® Track Max® Hydraulic Roller Camshafts for Ford 5.0L - Overview - SummitRacing.com
Edelbrock 2281 - Edelbrock Performer RPM Hydraulic Roller Camshafts - Overview - SummitRacing.com
Oh, I found a flow chart for the heads. A stock Cleveland 4V head flows about 300cfm on the intake, and 180 on the exhaust, both at .500 lift. Of all the aftermarket W heads, none can do that without some fancy port job. Those that do, flow a little better on the exhaust side, which is the Clevage's downfall. Summit has some nice iron heads for around $1300. But...it's just not that aesthetically special(visual appeal).
http://www.carbdford.com/tech/flowdata.htm
Old Jun 7, 2011 | 09:46 PM
  #344
nevrenufhp's Avatar
nevrenufhp
Edelbrock 7183 - Edelbrock Performer RPM Intake Manifolds - Overview - SummitRacing.com
Low and behold, Edelbrock even makes a Clevor intake now.
Old Jun 8, 2011 | 06:03 AM
  #345
Builtihtuff
I called that guy and left him.a message even with shipping here its a lil over 300
